any body have a idea - JeepForum.com
post #1 of 8 Old 11-15-2011, 11:03 AM Thread Starter
Buickzx1
I just put in a new fuel pump in my jeep now my jeep fuel gauge is not reading right any ideas
Buickzx1 is offline
post #2 of 8 Old 11-15-2011, 03:02 PM
yj381
Mine did that after a fuel pump replacement and it was because of a loose wire on the sending unit.
1995 yj, 2.5l, 2 1/2 skyjacker lift, 1" shackle lift, 1" prothane body lift, 33 x 10.50 bfg ko, raptor lined tub, original owner
yj381 is offline
post #3 of 8 Old 11-15-2011, 04:10 PM Thread Starter
Buickzx1
So for that I have to take it back out right
Buickzx1 is offline
post #4 of 8 Old 11-15-2011, 04:12 PM
WakeDoctor
Unless you are Matilda.
WakeDoctor is offline
post #5 of 8 Old 11-15-2011, 05:08 PM Thread Starter
Buickzx1
Great sounds fun
Buickzx1 is offline
post #6 of 8 Old 11-15-2011, 05:14 PM
92 Green YJ
92 Green YJ's Avatar
I'd say loose wire or the float thingy isn't set in there correctly. Either involves removing the pump assembly again to check
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #7 of 8 Old 11-15-2011, 06:59 PM Thread Starter
Buickzx1
Thanks,guys I will let u know what I find
Buickzx1 is offline
post #8 of 8 Old 11-24-2011, 07:54 PM Thread Starter
Buickzx1
So I took the tank back out and it was a loose wire on the sending unit so thanks agaim
Buickzx1 is offline
Tips for removing body spacer's. Recipricating Saw bad idea? carl6405 YJ Wrangler Technical Forum 9 03-09-2009 06:31 AM
Budget Boost & Body Lift Bad Idea? DesertTJ TJ Wrangler Technical Forum 17 02-24-2007 06:25 AM
Herculining hard top... good idea? bad idea? ScottJ83 TJ Wrangler Technical Forum 19 10-27-2006 05:31 PM
Idea for a body lift marcosesquan YJ Wrangler Technical Forum 14 03-09-2006 10:12 PM
Two inch body lift a bad idea?? hangten93 TJ Wrangler Technical Forum 14 10-23-2005 01:22 PM
