Antifreeze leak !!! - Page 2 - JeepForum.com
post #16 of 31 Old 10-20-2009, 02:57 PM Thread Starter
Dr.Dirty
there are freeze plugs in the side heres a pic
Dr.Dirty is offline
post #17 of 31 Old 10-20-2009, 02:59 PM
Anonymous6915
2009 JK Wrangler
pix not working. just getting a red "x"
Anonymous6915 is offline
post #18 of 31 Old 10-20-2009, 03:01 PM Thread Starter
Dr.Dirty
yeah im looking for a better picture lol
the ones on the side are simple to change
drain the coolant firts unless you want a collant bath lol
Dr.Dirty is offline
post #19 of 31 Old 10-20-2009, 03:03 PM Thread Starter
Dr.Dirty
Dr.Dirty is offline
post #20 of 31 Old 10-20-2009, 03:04 PM
Anonymous6915
2009 JK Wrangler
so just drain the coolant and pop it out with a screwdriver, then pop another one in?
post #21 of 31 Old 10-20-2009, 03:05 PM
Anonymous6915
2009 JK Wrangler
link says im not authorized to view...
post #22 of 31 Old 10-20-2009, 03:09 PM Thread Starter
Dr.Dirty
here is a good write up
How to replace a car engine freeze plug
Dr.Dirty is offline
post #23 of 31 Old 10-20-2009, 03:14 PM
Anonymous6915
2009 JK Wrangler
thanks for the write up. looks like ill be doing this sometime this weekend...
post #24 of 31 Old 10-20-2009, 03:17 PM
Anonymous6915
2009 JK Wrangler
on a side note. what do you think is the best and easiest way to drain my antifreeze?...
post #25 of 31 Old 10-20-2009, 03:19 PM Thread Starter
Dr.Dirty
its still going to pour out when you pull the freeze plug but it wont be as much as if you dont drain any.
i always just pull the lower radiator hose but everyone has their own way of doing it
Dr.Dirty is offline
post #26 of 31 Old 10-20-2009, 03:25 PM
Anonymous6915
2009 JK Wrangler
i see my local auto parts has two different size plugs. do i need the 1" or 2" diameter plug?
post #27 of 31 Old 10-20-2009, 03:27 PM Thread Starter
Dr.Dirty
i belive the sides are the 2 inch id buy one of each just in case lol hell id change them all being that youll have the collant drained already
Dr.Dirty is offline
post #28 of 31 Old 10-20-2009, 03:28 PM
Anonymous6915
2009 JK Wrangler
good point. thanks for all the info.
post #29 of 31 Old 10-25-2009, 10:09 PM
Anonymous6915
2009 JK Wrangler
ok so i did the freeze plug yesterday and everything seemed fine. i got in it this morning and started driving...leaks more now the b4. the freeze plug i used was the rubber one and it didnt leak after the install. could it be that i didnt tighten the nut enough? or should i just redo it with the solid plug?
post #30 of 31 Old 10-25-2009, 10:11 PM Thread Starter
Dr.Dirty
i would use the solid plugs the rubber are really for temporary fixes
Dr.Dirty is offline
Antifreeze Leak Cards89YJ YJ Wrangler Technical Forum 4 12-18-2009 03:06 PM
Antifreeze leak Matthew00 YJ Wrangler Technical Forum 6 05-11-2009 02:40 PM
Antifreeze leak nbrown YJ Wrangler Technical Forum 9 03-02-2007 02:59 PM
antifreeze leak baghdadman TJ Wrangler Technical Forum 3 03-25-2005 08:26 PM
Antifreeze leak GoTopless TJ Wrangler Technical Forum 3 08-26-2003 11:50 AM
