Antifreeze leak !!! - JeepForum.com
post #1 of 31 Old 08-24-2009, 09:02 PM Thread Starter
Dr.Dirty
Antifreeze leak !!!
well the jeep has been in the shop scince we put the new motor in it so i crawl underneath to install the ne magnaflow muffler and there was a decent size puddle of coolant it seems to be dripping from where the clutch is at
i cant feel any wetness on the back of the head and cant see any visible leaks
any ideas its a 95 yj 4.0 5spd
Dr.Dirty is offline
post #2 of 31 Old 08-24-2009, 11:24 PM
idaholtby
You are probably not going to want to hear this, but there is a freeze plug behind the flywheel. That would explain the coolant leak coming from the clutch area.
idaholtby is offline
post #3 of 31 Old 08-24-2009, 11:36 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Use a mirror & a light to check above the bellhousing for signs of leakage before yanking the tranny.
It's a long shot, but maybe your head gasket is leaking? I can't recall if the 4.0L head has a freeze plug in the back of the head, but it may. Check it out.
Short of that, idaholtby is right, tranny removal may be in your future.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 31 Old 08-25-2009, 08:59 AM Thread Starter
Dr.Dirty
Thanks guys i figured thats what it was but was hoping the best lol so i guess ill be pulling the tranny today lol
Dr.Dirty is offline
post #5 of 31 Old 08-25-2009, 12:09 PM
TSEJEEPERS
Isnt the temperature sensor on back of the engine? Does that go into a water jacket?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #6 of 31 Old 08-25-2009, 04:00 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes, it is. But it's more "on top" than on the back. You would more than likely smell it burning off the exhaust manifold, rather than seeing a drip at the bellhousing with a leaky sender.
Here is a link to a REALLY huge pic of the sender & it's location.
http://www.baeta.org/opie/images/Jee...20IMG_9297.JPG
Max
Mean Max is offline
post #7 of 31 Old 08-25-2009, 06:54 PM
jaw41272
jaw41272's Avatar
yup freeze plug behind the bell housing, Mine leaks slightly as well, bars leak to the rescue!
91 Sahara 4.0l Operation Welcome Home Parade Veh #69
PARADE JEEP MEMBER #1Auto posi-lok equipped, 4" susp. lift
K&N Drop in and loaded with battle scars
FOR SALE 2005 PT CRUISER CONVERTIBLE
2005 Suzuki DRZ400S For SALE
jaw41272 is offline
post #8 of 31 Old 08-25-2009, 10:25 PM Thread Starter
Dr.Dirty
not sure if i want to put bars leak in a brand new motor
Dr.Dirty is offline
post #9 of 31 Old 08-26-2009, 12:08 AM
MJMPC
If you have a new motor dont you have new freeze out plugs ?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #10 of 31 Old 08-26-2009, 08:26 AM Thread Starter
Dr.Dirty
yes they are new freeze plugs also but apparently one is no good lol
Dr.Dirty is offline
post #11 of 31 Old 08-26-2009, 12:09 PM
jaw41272
jaw41272's Avatar
i wouldnt put bars leak in a new motor either, and it kills me to have it in mine...... but I am too lazy to drop my tranny, maybe in the early spring........
jaw41272 is offline
post #12 of 31 Old 10-20-2009, 02:47 PM
Anonymous6915
2009 JK Wrangler
ok so i know this is an old thread and i was pretty sure i had a leaky freeze plug by my trans. i recently did my clutch and while i had the trans out, i checked and that plug is solid. i have another plug on the side of the engine that looks identicle but more rusted out and its leaking.
my questions is; is there more then 1 freeze plug? if so does anyone have a link to a write up for fix?.
Anonymous6915 is offline
post #13 of 31 Old 10-20-2009, 02:50 PM Thread Starter
Dr.Dirty
I still havent pulled the tranny lol one it warms up it stops leaking . Im waiting till i find a automatic tranny to swap
Dr.Dirty is offline
post #14 of 31 Old 10-20-2009, 02:51 PM Thread Starter
Dr.Dirty
here is a pic i found on the forum
im thinking mine is the one on the left because thats were its dripping from
Dr.Dirty is offline
post #15 of 31 Old 10-20-2009, 02:55 PM
Anonymous6915
2009 JK Wrangler
the pic above is not where mine is leaking from. mine leaks from the side of the block. i just want to make sure its a freeze plug and i dont go pounding a hole on the side of my engine.
Antifreeze Leak Cards89YJ YJ Wrangler Technical Forum 4 12-18-2009 03:06 PM
Antifreeze leak Matthew00 YJ Wrangler Technical Forum 6 05-11-2009 02:40 PM
Antifreeze leak nbrown YJ Wrangler Technical Forum 9 03-02-2007 02:59 PM
antifreeze leak baghdadman TJ Wrangler Technical Forum 3 03-25-2005 08:26 PM
Antifreeze leak GoTopless TJ Wrangler Technical Forum 3 08-26-2003 11:50 AM
