anti-drainback valve question - JeepForum.com
post #1 of 10 Old 08-28-2011, 12:53 PM Thread Starter
brandolabs
Looking for some expertise. So for the last month or so my YJ has been slow to start (3-5sec crank). connections are solid, new redtop optima (6 months), and a new starter (4 months). Through all of my forum searching it seems that my problem is most likely my anti-drainback valve leaking or losing pressure so that when I start my jeep the pump has to pump the fuel before it can fire blah blah.
Question is, how much of a pain in the butt is it to replace and is it worth doing before I sell. Selling because i've got a squirrel 4 cyl and I need more power. any responses are much appreciated, thanks guys
brandolabs is offline
post #2 of 10 Old 08-28-2011, 01:01 PM
Desert_Rampage
1991 XJ Cherokee
I have this same issue. Where is said drainback valve? I have access to ALLDATA but not at the moment.
Sent from my Droid using JeepForum
"Chainsaws can dismantle anything... Or you can just take it apart by removing screws until it opens, but what fun is that? "--Motoman22
Desert_Rampage is offline
post #3 of 10 Old 08-28-2011, 06:58 PM
Desert_Rampage
1991 XJ Cherokee
bump
post #4 of 10 Old 08-28-2011, 08:18 PM
deathtrap
The drain back check valve is in the in tank fuel pump, you gotta replace the pump. If your fuel pres. is ok
once it is running I doubt it will cause low power just long crank time.
deathtrap is offline
post #5 of 10 Old 08-28-2011, 08:20 PM
Desert_Rampage
1991 XJ Cherokee
What if it's a carb'd engine? Wouldn't it be the filter itself acting as a valve?
post #6 of 10 Old 08-28-2011, 08:26 PM
deathtrap
Carb engines dont realy need one because fuel is stored in the carbs float bowl when the engine is not running.
post #7 of 10 Old 08-28-2011, 08:31 PM
Desert_Rampage
1991 XJ Cherokee
True True. Idk, I have the 4.2 w/ 32/36 Weber and mine takes ages to crank after sitting for any length of time. Kinda irritating.
post #8 of 10 Old 08-29-2011, 09:53 AM
Que89YJ
Your bowl might be evaporating off the full if it's hot and a while inbetween starts.
Que89YJ is offline
post #9 of 10 Old 08-29-2011, 12:28 PM
vadslram
Mine did that too. Carbed w/MC2100. It was kind of annoying. I even popped the top of the carb and the fuel had drained right to the needle float.
I switched out the fuel filter and that fixed it. I guess at least on mine the anti drainback is in the filter.
vadslram is offline
post #10 of 10 Old 08-29-2011, 01:24 PM
Alabamaranger
I was wondering to. Mine is a 4,2 with a MC2150 carb. It turns over more when sitting a few days. I run the fuel filter with the fuel return hose.
My son has the same carb on his Ford Ranger with no fuel return filter. His starts up a lot more quickly. So I guess it's psooible for the fuel to go back to the tank and drained up to the needle valve inside the carb. With the fuel filter return, after shut off, there should be no fuel pressure at the carb since it's vented back to the tank on the re.
I learned that the fuel filter return line, had to be at the 12:00 position, It was to keep fuel flowing to prevent line lock up from heat, and to releive the pressure from the fuel pump when it's not needed as much (idle).
Most Fords do not have return lines. So I am wondering if you have a carter or motorcraft, that the fuel return can be eleminated?
90 YJ, 4.2 with 2150 carb 4.0 Head and headers, Nutter with TFI and MSD. 1" BL, 2.5" spring lift, 33", Goodrich KM Mud Tires. Dana 30 w Aussie, Ford 8.8 w LS. 9000lb HF Winch.
Alabamaranger is offline
anti-drainback valve , YJ
Anti-drainback valve question hutch1973 TJ Wrangler Technical Forum 12 04-19-2015 09:57 PM
Anti Drainback Valve Replaced - Still Slow Start seabass2020 TJ Wrangler Technical Forum 10 05-21-2009 08:30 AM
Location of fuel pump anti drain valve? Vladimer TJ Wrangler Technical Forum 0 06-16-2008 09:18 PM
Anti-drain Back Valve???? BumbleBeeTJ TJ Wrangler Technical Forum 8 10-15-2004 10:21 PM
