Another YJ light thread.... - JeepForum.com
post #1 of 127 Old 09-26-2014, 06:17 PM Thread Starter
amp713
Ok guys i know there are a few of these but some of this stuff has me confused.
First off, i was going to do the wiring mod but found this: http://www.ebay.com/itm/161373981690
Plug and play is nice, plus the price is close to what relay and inline fuses and splices could cost.
Second is everyone talks about the H4 upgrade. Is this bulb a HID wannabe? I know HID's in non HID housings kinda suck for the other people around. Want to find a set of lights that give me great light but dont get me flashed constantly on low, I DO NOT WANT to install ballasts.
Ive seen a lot of different posts and opinions but my biggest question i guess is whats the big deal with the H4 conversion?
I like my YJ how I like my whiskey, on the rocks with just a touch of color!
amp713 is offline
post #2 of 127 Old 09-26-2014, 07:26 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
I was under the impression the h4 housings were just shells that take regular screw in bulbs, vs replacing the 6054 headlight as a whole unit. Then there are the ones that are e-code which is just a different light pattern. While I havent messed with any of this, what I can tell you from research is the relay/harness will be the first step. That alone will whiten/brighten the standard bulbs enough to most peoples liking. My friend did the relay and some high end regular lights similar to silverstar but something else, needless to say he was blinding me all the way home last week.
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
post #3 of 127 Old 09-26-2014, 07:30 PM
Chrisnvegas
Chrisnvegas's Avatar
I recommend the wiring mod if your headlight circuit is suffering from low voltage.
Then for headlights I like the GE Nighthawk. A nice white light, still legal, sealed beam tough, reliable, and a fairly well cut lens for an el cheapo headlight.
These were better than the regular halogens, or the silverstars that I had.
I like sealed beam for my primary headlights. They will handle being submerged (you never know) and are pretty tough with rock hits.
I think it's a waste getting all fancy with headlights.
Then run this setup for off road use. HID's and LED's mixed. HID's still have a distance advantage over LED, so I run both. How do you say daylight?
"Auto racing began 5 minutes after the second car was built."
Henry Ford
Chrisnvegas is online now
post #4 of 127 Old 09-26-2014, 07:36 PM Thread Starter
amp713
Ya i didnt really get why everyone talked about H4's so much... I mean ya a bulb easier to change but those sealed beams can be picked up everywhere..... Better get on it man!
That is a lot of light! hahaha did you do a plug and play kit or cut and splice status??? I wanna keep everything square on the YJ just to further bug the round headlight guys.
amp713 is offline
post #5 of 127 Old 09-26-2014, 07:42 PM
Chrisnvegas
Plug and play.
And those H-4's suck. If you barely touch the bulbs, they're cooked. I have not had the best luck with H-4.
I prefer putting my money where it counts. The real stuff up top.
40 bucks for two and they are pretty darn good headlights. Just be sure to aim them the way you want em.
http://www.amazon.com/GE-H6054NH-Nig...ype=automotive
Henry Ford
post #6 of 127 Old 09-26-2014, 09:16 PM
Drednot
I've had great luck with H4 bulbs. They are available everywhere sealed beams are sold. If you accidentally touch the bulb, you just have to wipe it off with alcohol. I run Cibie E-code housings with 55/60 watt bulbs and have all the light I could want.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #7 of 127 Old 09-26-2014, 10:00 PM Thread Starter
amp713
How much do those E code housings run?
amp713 is offline
post #8 of 127 Old 09-26-2014, 10:03 PM Thread Starter
amp713
Originally Posted by Chrisnvegas View Post
Plug and play.
Im looking into those right meow. I realy think ill try to find a sealed assembly that looks not so stock just to have something a bit different.
amp713 is offline
post #9 of 127 Old 09-27-2014, 12:18 AM
Drednot
I want to say mine were $78. Each
http://www.headlightservices.com/Headlamps.html
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #10 of 127 Old 09-27-2014, 04:20 AM
Drednot
I still need to get better comparison photos on a nice dark road, but I have these for now.
The halogen pattern by itself.
The E-code pattern by itself. 55w. No relay upgrade.
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #11 of 127 Old 09-27-2014, 11:51 AM
140mower
I have also had good results with the H4 Halogens, but you do need to upgrade the wiring to get the best results..... One thing I like about them is the wide range of different wattage bulbs you can get to fit the housings. I run ones with the stock 55w lowbeams and 100w Highbeams, I use a continuous duty solenoid rather than a relay for switching them with excellent results.
If it wasn't done the hard way, I didn't do it.
140mower is offline
post #12 of 127 Old 09-27-2014, 04:53 PM Thread Starter
amp713
Grabbed a set on ebay to try! I also have the plug and play relay harnes on the way also! Hope it turns out as good as it is in my head!
amp713 is offline
post #13 of 127 Old 09-27-2014, 05:28 PM
youngjeepr
Ive got h4 autopal housing in my jeep with 60w hella bulbs. They work MUCH better than the stock lights.
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #14 of 127 Old 09-27-2014, 09:28 PM
brianhorne8
I'm installing plug and play relays from Octane Lighting tomorrow, along with Hella H4 housings. I'll report back, but they can't be any worse than what I've got in now are.
brianhorne8 is offline
post #15 of 127 Old 09-27-2014, 10:08 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I did ecode (not the diamond cut crap ) h4 housings and a upgraded harness in my XJ. It was big improvement over the stock lighting however it sucks compared to my retrofitted hid's in my YJ.
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
