Another tire and lift question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Another tire and lift question
The Original 3/8" Ruffstuff Diff Cover!Safety Thimble FairleadsEngo winches available at www.rockridge4wd.com! Free shipp
Unread 10-16-2014, 12:24 PM   #1
Bigverv
Okay, a few questions. I took these factory rims
Plasti-dipped them to look like this
And I really like how they came out
Now I am at a dilemma. I want to put an OME 2.5" on and am wondering the following:
1-what is the width of these rims? I am looking to get 31-10.5-15s
2- will the backspacing of these rims (and the tires I want to put on them) be sufficient so I don't have rubs and can fully turn?
3- if not, are spacers recommended? Or just lose the factory rim idea and go with something with more backspacing?
4-kind of unrelated, but some folks say a t-case drop is needed on a 2.5" and other say it is only needed for a 4" or more. Is there a definite answer?
Really would like to stick with these rims, since I put a lot of work into them and like how they turned out, but I am at a point where my tires are getting really bad, and my springs are almost flat, so I may as well get the lift now so I don't buy tires that I won't be using after the lift is installed. Thoughts?
Bigverv is offline   Reply With Quote Quick reply to this message
Unread 10-16-2014, 12:29 PM   #2
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
1. 7" 31-10s will be fine
2. Stock backspace, you will be fine
3. No standard answer here, gonna have to install it and take er for a spin.
Mark
Smoke em if you got em!
Click here
Mobile_Homie is offline   Reply With Quote Quick reply to this message
