Another Swing-Out Spare Carrier Build - Page 2 - JeepForum.com
post #16 of 18 Old 04-21-2010, 10:39 AM Thread Starter
DaveinHouston
I finally got around to lowering the jack mount. I moved it to the front side of the carrier frame and dropped it about eight inches. This makes for better security too as you can't remove the jack without swinging open the carrier. So as long as the carrier is locked in place you can't remove the jack. The visibility through the rear view mirror is much better now.
- 2003 Rubicon - 4" Lift, 35" KM2s, 5.13 gears, winch
- 1968 CJ5 - Dauntless V6, T-86, Dana 18, D27 & D44
- NRA Life Member - Licensed to Carry and Do.
DaveinHouston is offline
post #17 of 18 Old 04-27-2010, 11:51 AM Thread Starter
DaveinHouston
I decided to modify my carry basket so it sits on top of the carrier instead of hanging off the back of it. This moves the weight much farther forward and should reduce the load on the hinge. I put rubber bumpers on the basket with about 1/4" clearance between the back glass in case it bumps up against the glass. I also put another rubber bumper on the outside edge of the basket where it hits the Jeep top when it's swung all the way open. I modified the carrier latch to get it out of the way of the license plate holder/gas cap cover. I may build a gas can carrier at some point but I think this will be it for a while.
post #18 of 18 Old 04-27-2010, 11:56 AM
jeep350chevy
1987 YJ Wrangler
Very nice job
jeep350chevy is offline
PISSED! OEM Spare Tire Carrier Bolts Just Spinning, Can't Get Spare Off! IDEAS!?! chicagoanalog TJ Wrangler Technical Forum 20 09-24-2012 06:12 PM
CJ spare swing out wantajeep631 YJ Wrangler Technical Forum 32 12-05-2009 09:01 AM
Swing Out, Swing Down Tire Carrier? uvalax236 TJ Wrangler Technical Forum 14 06-27-2009 09:05 AM
want to build my own spare tire carrier txlegman TJ Wrangler Technical Forum 4 03-09-2009 07:04 PM
cheap swing away spare tire??? asjeep TJ Wrangler Technical Forum 1 09-08-2003 10:06 PM
