Another squeaky fan belt issue - JeepForum.com
post #1 of 7 Old 01-22-2014, 04:45 PM Thread Starter
kahanabob
92 4.0 2WD.......fan belt started to squeal all of a sudden. i removed it and cleaned it and all the groves in all the pulleys. while apart i turned all the moving parts and they all seemed fine. put it together and same issue. while running i sprayed WD-40 on the belt and the squeal went away for about a minute then returned. seems to me the WD-40 fixing it for a minute ruled out any issues with the alternator and PWS pump. observed the pulleys while running and no wobble or anything out of the ordinary. fan belt is like new still had the bend in it from being in the box.
any ideas....
kahanabob is offline
post #2 of 7 Old 01-22-2014, 05:16 PM
Mark05059
use carb cleaner or brake cleaner instead of wd40
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 7 Old 01-22-2014, 05:18 PM
Jeepsr4me
Take belt off and spin the things that will spin. One of them is about to go out and will be tighter than the rest.
Or the belt is not tight enough
Jeepsr4me is offline
post #4 of 7 Old 01-22-2014, 05:30 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Everything clean and degreased? Check.
No pulley makes noise while manually spinning when belt is off? Check.
Belt on just a little tighter than you think it should be? if not = Belt not tight enough.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is online now
post #5 of 7 Old 01-22-2014, 05:48 PM Thread Starter
kahanabob
i just drove it to the store and back squealing all the way. when i got home noticed water dripping under. guess i will be changing the water pump tomorrow.............
post #6 of 7 Old 01-22-2014, 06:24 PM
ted1888
had same problem with 97tj tried tighting cleaning and checked idler and otherpulleys belt looked good /bought new cheap belt fixed problem for almost a year. then problem returned tried everything again. talked to other jeepers was advised to spend a little more money and buy a better belt.installed a new one/problem solved 3years ago. but make sure pulleys are in line. good luck.
ted1888 is offline
post #7 of 7 Old 01-23-2014, 06:59 PM Thread Starter
kahanabob
installed new water pump, old one was bad but the belt still squeals. how tight is it supposed to be? i have another belt i will try. the one on there now has unbroken groves in it the other one i have has cross hatches on a angle, if i am making any sense. i saw somewhere some of the belts will stick in the groves of the pulleys?
