Another Shake at Idle Problem - JeepForum.com
post #1 of 10 Old 02-06-2013, 11:40 AM Thread Starter
ridgeback_king
Ok I'm going to outline the problem, and everything I've done to date to try and fix it so that you guys don't have to waist time guessing what I should do next.
It's a 95 YJ 2.5l
The Problem:
- I start it up and it idles nicely at 1000rpm.
- A half mile from my house at a stop sign it's still idling at 1000rpm.
- After 5 minutes of driving, any stop that I come to it idles at 500rpm and just does an annoying shake. It's not loud or anything, just more like a rumble.
- When I give it gas, it sounds and runs great. Idling is the only issue. It drops immediately to 500rpm everytime I stop.
Things I have done to try and fix it thus far:
- Checked for vacuum leaks and found a leaking intake manifold. Fixed that, idle problem remained.
- Cleaned out the entire throttle body, including the IAC value.
- Replaced the Timing Chain, Gears, and Tensioner.
- Replaced the Map Sensor.
- Replaced the O2 Sensor.
- Other items that are fairly new on the Jeep are the PCV Valve, Water Pump, fan belt.
Only remaining things that I can see being the issue:
- Instead of cleaning the IAC valve, just replacing it. I don't know how to tell if it's bad.
- Replacing the Throttle Position Sensor
- Replacing the Motor Mounts. I don't believe they've been replaced, and I can't really tell if they've gone bad. The driver side one seems to have some of the rubber padding missing.
Your opinions would be greatly appreciated, and thank you ahead of time.
ridgeback_king is offline
post #2 of 10 Old 02-06-2013, 01:39 PM
Reddy89
Does it idle steadily at 500rpms or is shaking like it's about to stall, starving for gas?
Reddy89 is offline
post #3 of 10 Old 02-06-2013, 01:48 PM Thread Starter
ridgeback_king
It idles at 500 rpm steady... Drops to 500 and stays there.
post #4 of 10 Old 02-10-2013, 09:46 PM Thread Starter
ridgeback_king
Nothing?
post #5 of 10 Old 02-10-2013, 10:14 PM
Reno72
Sounds like you've done a lot. Is it throwing any codes? Did you check for clogged vacuum lines? I had a clogged line at the manifold. I would check all the emission lines and sensors. I don't have the 2.5 but 500rpm sounds like a slow idles, I imagine 750 would be about right but there is no real way to speed it up with the computer. How does the fuel pump sound, does it pressure up right away? If it is going out or clogged it may show up more at idle. How is the temperature reading? There are so many sensors on these things that will affect how the vehicle idles and runs. Sorry but you've done most of what I would have looked at.
Reno72 is offline
post #6 of 10 Old 02-10-2013, 10:23 PM Thread Starter
ridgeback_king
- It's not throwing any codes.
- I checked for vacuum leaks, but not vacuum clogs. What's the best way to find out if something's clogged. Would it be visually noticeable?
- Haven't checked the fuel pump.
- Temperature reads fine.
I'll try and take a look at these things thank you!
post #7 of 10 Old 02-10-2013, 11:51 PM
ROTTEN
Mine idles below 500. Almost to the last rpm line
I believe I have an intake leak
Try tightening up the rear bolts on the manifold. Worth a shot and free
I'm new
ROTTEN is offline
post #8 of 10 Old 02-11-2013, 04:39 AM
95yj0645
Any vacuum leak on a fuel injected engine SHOULD bring your idle up. (computer senses more air adds more fuel= more RPM).. replace your iac mine is doing the same thing.
95yj0645 is offline
post #9 of 10 Old 02-11-2013, 09:11 AM
Reno72
I think a leak only brings the idle up for a second till the compter refigures and adjusts. Then I beleive it will run rich, but not at all smooth. (I may be wrong, it's what i noticed on mine)
Reno72 is offline
post #10 of 10 Old 02-11-2013, 04:26 PM
95yj0645
Im just saying replace the IAC because I know for a fact mine does not work and it is doing the exact same thing idling super floaty around 500-700 rpm. If you have access to a nice snap on scan tool you should be able to do a function test on the IAC, as well as watch your ST-LT fuel trim.
95yj0645 is offline
