Another round of name that part. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Another round of name that part.
TeraFlex Now at Rockridge 4WD! BEST DEALS around!Alloy usa heavy duty ball joint kitsENGO QUADLUX 6" to 54" LED AMBER AND WHITE MULTI
Unread 06-20-2014, 04:57 AM   #1
hardluk
1987 YJ Wrangler
Taking my tranny out I found this burnt plug zip tied up under the floor panel.
hardluk is offline   Reply With Quote Quick reply to this message
Unread 06-20-2014, 05:07 AM   #2
grandboost98
Not sure what its for, but I do know it connects on the passenger side near the fill plug
89 Jeep Wrangler - 3.5" HD BDS lift and M.O.R.E. HD 5/8" booms on 33s
99 Jeep Cherokee - 2 door, 5" lift on 33" super swampers
72 Chevy Nova - build in progress
98 Pontiac Grand Prix GTP - too many mods to list::SOLD::
grandboost98 is offline   Reply With Quote Quick reply to this message
Unread 06-20-2014, 06:22 AM   #3
Michaelgoesrawr
Michaelgoesrawr's Avatar
I was gonna say it looks like the reverse light switch.
Edit: That's auto so nvm. I dunno.
Michaelgoesrawr is online now   Reply With Quote Quick reply to this message
Unread 06-20-2014, 08:23 AM   #4
Que89YJ
One way to tell for sure. Short the 2 wires together and see what lights. I think Mikes right.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 06-20-2014, 09:56 AM   #5
warthog312
The Craigslist Crawler
warthog312's Avatar
Get yourself a schematic (Hayes, Chiltons, etc.) and play the "follow the diagrams" game until you can identify the wire colors and plug. Personally, if I were running without something like that for a long time and everything seemed fine, I'd just let it be; but I'm no professional mechanic....
Click for build thread: HONEYBADGER - 302//435//20//8.8
>>>the single greatest investment you can make for your jeep is to buy a good welder, and learn how to use it<<<
warthog312 is offline   Reply With Quote Quick reply to this message
Unread 06-20-2014, 10:19 AM   #6
bpounds
bpounds's Avatar
The backup lamp switch wire colors would be yellow w/trace and brown w/trace. Clean up those wires and check the colors.
You can download the FSM for your '87 and it has the schematics in it. That's where I got those colors.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline   Reply With Quote Quick reply to this message
Unread 06-20-2014, 10:28 AM   #7
superj
1987 YJ Wrangler
thats an auto? maybe its the neutral safety switch? do you have a stock solenoid on the jeep? the neutral safety switch hooks to the third pole on the stock solenoid, the bottom pole. if you have a two pole solenoid and a spare plug hanging by the solenoid, that is probably what it is
Slow ride, take it easy
superj is offline   Reply With Quote Quick reply to this message
Unread 06-20-2014, 10:41 AM   #8
hardluk
1987 YJ Wrangler
My backup lights work. Thanks for the link que I have a Haynes manual my little girl likes to color in it. I have found that's about all it's good for. I'll trace it out when I get back home but I've been thinking about it all morning and I've never had a 4wd light. PO installed a posi lock cable on the CAD but did a real crappy job. I think he used a bicycle brake line and didn't even seal the cover up. That's next on my list after this slave conversion.
Unread 06-20-2014, 10:42 AM   #9
hardluk
1987 YJ Wrangler
Ax/5 manual
Unread 06-20-2014, 11:07 AM   #10
HaskiE
HaskiE's Avatar
I think my Haynes manual is my favourite book of all!
#theneverendingaxe
HaskiE is offline   Reply With Quote Quick reply to this message
Unread 06-20-2014, 11:25 AM   #11
Que89YJ
Funny you should say 4wd light That was my first post. Search the pdf by wire color or the forum. I am pretty sure it comes up too.
Unread 06-20-2014, 02:12 PM   #12
YJ4LIFE
4wd light should be from the firewal vacuum switch no?
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline   Reply With Quote Quick reply to this message
Unread 06-20-2014, 03:54 PM   #13
Michaelgoesrawr
Depends on the year.
Early model it's a vacuum switch. Some time in the early 90's they switched it to electric on the CAD.
