Another regearing question - JeepForum.com
post #1 of 4 Old 10-14-2011, 09:24 AM Thread Starter
40FiveSeventy
Hey guys,
Before anyone throws things, I did a keyword search for my question, but didn't come up with anything conclusive. After my adventure of losing a tire, I'm going to obviously be putting new tires on my jeep. I'm looking at 31's that will fit on stock rims, so I don't have to do any spacing or lifting right off the bat. I also understand that upping the tire size means regearing AND changing the speedo gear to be accurate - but here's my question - does it matter which of those I do first? I figured it should go - Tires -> Regear -> Speedo gear, because how many teeth you need is dependent on the tire/gear ratio matrix, right? Just looking for some clarification. I don't want to do things wrong.
Thanks!
-The Mad Cap.
~*4FS.
40FiveSeventy is offline
post #2 of 4 Old 10-14-2011, 09:57 AM
bogleparsons
Bro, I really don't think a re-gear is worth your $$$. Unless you had bigger tires,
I have 30X9.5r15's and there is not a noticeable loss in power from my beastly 2.5 (sarcasm)
1" larger is not gonna kill yer engine.
The speedo gear is like >$10 so yea have at it
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #3 of 4 Old 10-14-2011, 10:03 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
For 31's on your 2.5L, 5 speed, I doubt that I'd do a gear change. It should be tolerable.
Now if you are getting some 4.56's or 4.88's SUPER cheap (since you should already have 4.10's), it might be worth it. But if you are buying new gears, bearings, master install kits, and paying a shop to do the work, it'll cost some serious coin $$$.
Joe Dillard is offline
post #4 of 4 Old 10-14-2011, 10:10 AM
jsawduste
2006 YJ Wrangler
Originally Posted by 40FiveSeventy View Post
Hey guys,
Thanks!
You got it !!
But will comment that you might not need to regear if you are happy with the performance. In fact I`d bet you with that small of a tire change you won`t need to.
Speedo gear. I`d use a GPS to see how much your speedo is off. Do not think it will be much. Yes, I am taking into account the ECM and VSS signal.
Put some fresh meats on it. Drive it for a week or two. Then make your decision(s).
Here is a chart you can play with
http://www.grimmjeeper.com/gears.html
Just for kicks I plugged some numbers in
AX-15 trans.
30 to 31 inch tires
3.73 gears
231 TC
Found a 3 mph difference at 2500 RPM with going from 30 to 31`s.
No worries
jsawduste is offline
Regearing Question 3.07 to 4.56 dadlife TJ Wrangler Technical Forum 5 09-18-2011 06:00 PM
regearing question Zeusismyonlygod TJ Wrangler Technical Forum 4 11-04-2010 10:43 PM
Question about regearing. BChamberlin TJ Wrangler Technical Forum 12 07-01-2008 10:41 AM
question about regearing??? hiram TJ Wrangler Technical Forum 2 03-09-2007 06:03 PM
regearing question mic6 TJ Wrangler Technical Forum 12 08-19-2005 01:39 PM
