Another question. This time locker - JeepForum.com
post #1 of 12 Old 04-27-2015, 02:04 PM Thread Starter
Rabbitsh
I just bought this locker second hand ARB. Dana 35.
But while i was handling it (without care) i broke the small copper line.
A friend told me if i weld it maybe ill damage the diaphragm.
What is the best solution to fix it?
IMG_20150427_142632963.jpg   IMG_20150427_145552531.jpg   IMG_20150427_145626365.jpg   IMG_20150427_145635364.jpg
Rabbitsh is offline
post #2 of 12 Old 04-27-2015, 03:02 PM
jeepster93
jeepster93's Avatar
That is a pressure sleeve. You need a new one. Easy enough to replace while you have it out. Any ARB dealer can get you one.
The thing about those sleeves are...
Some are inside the bearing and some are outside the bearing. the inside ones require one to press remove and press the bearing back on. An Auto shop function mostly.
Looks like yours is outside, lucky you.
It looks like this.
jeepster93 is offline
post #3 of 12 Old 04-27-2015, 03:20 PM Thread Starter
Rabbitsh
Is very hard to get parts here in Mexico, also very very expensive. Ill check if my friend can weld it with few heat for dont damage it more. And if i get the piece it will cost me to much and takes 2 months to get here. >.<
Rabbitsh is offline
post #4 of 12 Old 04-27-2015, 03:45 PM
jbolty
jbolty's Avatar
it can probably be brazed in if you can get it fully apart.
jbolty is offline
post #5 of 12 Old 04-27-2015, 08:06 PM
TSEJEEPERS
Make sure you pull the seals out first!
Soldering will work.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #6 of 12 Old 04-27-2015, 08:21 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I wouldn't be surprised if it has other issues.
EG: What's all those grinding marks all about?
My guess would be that whatever gear set it was used with before tried chewing the body of the ARB up.
Joe Dillard is offline
post #7 of 12 Old 04-28-2015, 12:08 PM Thread Starter
Rabbitsh
Dillard, do you think that the chew in the locker case is a big problem?
Rabbitsh is offline
post #8 of 12 Old 04-28-2015, 03:04 PM
Joe Dillard
I can't say with any degree of certainty.
However, something fairly catastrophic occurred which caused somebody to grind the body down. My guess is that the pinion gear either walked out (actually in) enough or was bent & deflected enough to cause serious teeth gouging to the ARB.
There are a number of things that can cause or contribute to this.
Personally, I wouldn't run it - even if it were free due to a long laundry list of reasons.
post #9 of 12 Old 04-28-2015, 05:09 PM Thread Starter
Rabbitsh
I think the pinion was loose and make those marks :/ Ill see how it works in a month >.< And ill try to learn how use micrometer so maybe i can install myself. If not at least ill have experience for later x,x
Rabbitsh is offline
post #10 of 12 Old 04-29-2015, 09:38 AM
mike134
I would see if I could tap the hole with FNPT threads and put an adapter on if you can get it to all fit inside the housing.
mike134 is offline
post #11 of 12 Old 04-29-2015, 10:21 AM
timatoe
timatoe's Avatar
I'd order the new bearing seal. I hate "fixing" something and putting it all back together for it to not be "fixed".
timatoe is offline
post #12 of 12 Old 04-29-2015, 10:27 AM
mike134
That's a good point.
Also, Joe Dillard makes a good point... But in response to his comment, I would say keep it in mind but proceed. This may be your chance to rid yourself of your D35 anyway. Repair and install the locker and give it a go. If everything instantly explodes, install Ford 8.8 and be done with it.
mike134 is offline
