Another one of those Noise I can't find threads...:) - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Another one of those Noise I can't find threads...:)
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 08-19-2011, 07:32 PM   #16
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
I'm glad it turned out to be a simple thing. Can't tell you what to torque it to, I can't even remember having one of those on my Jeep.
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade: http://www.jeepforum.com/forum/f12/9...grade-1287758/
5.7YJ is offline   Reply With Quote Quick reply to this message
Unread 08-19-2011, 08:51 PM   #17
HanksRide
HanksRide's Avatar
I may be calling it the wrong thing, I believe that is what it is called. It is the rubber bushing mount thingy that is just to the drivers side of the tranny mount. I can't tell that it really does a whole lot but apparently it keeps things from bouncing when you hit bumps. It is almost hour glass shaped and looks to have two rubber bushing things end to end with a bolt through the center.
HanksRide
(Hank is Yellow Lab) He loves it!!
95yj 4.0L, 4" RC Lift, 8.8, Aussie Locker, Posi-Lok, Rock Sliders, 1" Booms, 33 X 12.50's, Rhino Lining, KC Day Lighters, Rock Bumpers, LED Dash Lights, XRC10 Winch
3500 Mile Road Trip With Daughter
Daughters 04 TJ Build Thread
My-95-YJ Build Thread
HanksRide is offline   Reply With Quote Quick reply to this message
Unread 08-20-2011, 08:32 AM   #18
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
I think you are right, I had to look it up cause I thought you may have meant a third link or something. I just didn't remember one on mine when it had the old engine.
Unread 08-20-2011, 09:02 AM   #19
LordEnki
2006 WK
Isn't it called the torque arm?
LordEnki is offline   Reply With Quote Quick reply to this message
Unread 08-20-2011, 09:44 AM   #20
Roadyy
Yes it is the Transmission Torque Arm. It has a bolt running all the way through the skid plate with a nut at both ends and a bushing above the torque arm. I just noticed mine is worn out aswell and was going to order one til I found a 4.0 drivetrain last night. You should just need to snug it down real good as I have not found any torque specs for it.
Roadyy is offline   Reply With Quote Quick reply to this message
Unread 08-20-2011, 10:01 AM   #21
1993BlackYJ
Had the same noise and it was a leaf spring bushing that was ate up and the bolt was just clanking around in the leaf eye
1947 CJ-2A
1953 CJ-3B "Ray"
1957 CJ-3b "Jeep with no Name" Parts Donor
1971 CJ5 "Dorothy" 225 Dauntless V6
1993 Black YJ 4.0L, 5 speed, Posi-Loc, 35x12.50 MTZ, 4" Skyjacker lift, Ramsey 8500 Winch, OBA, Front Aussie Locked, 8.8 ARB Rear, 4.10s
[SIZE="3"][B][B]My 93 Build Thread Over 700pics :[/B] [COLOR="Red"][url]http://www.jeepforum.com/forum/f12/my-1st-jeep-build-1993yj-938195/[/url][/COLOR][/B][/SIZE]
[SIZE="3"][B][B]My 71 "Dorothy" Build Thread Lots of pics :[/B] [COLOR="Red"][url]http://www.jeepforum.com/forum/f8/1971-cj5-dorothy-1122276/[/url][/COLOR][/B][/SIZE]
[B][SIZE="3"]My 53 CJ-3B "Ray" Build[/SIZE][/B]:[SIZE="3"][url]http://www.jeepforum.com/forum/f8/1953-cj-b3-ray-1268717/#post12217917[/url][/SIZE]]
[B][I]Jesus Christ is my Lord and Savior[/I][/B]
1993BlackYJ is offline   Reply With Quote Quick reply to this message
