Another one of those Noise I can't find threads...:) - JeepForum.com
post #1 of 21 Old 08-17-2011, 07:44 PM Thread Starter
HanksRide
OK first things first, my jeep is running, driving and riding great except for when I hit a bump. I have noticed lately that when I hit a bump going slow like on a paved back road that I get a bang noise like you would think the U-bolts were loose on one of the front axles. I have checked all of them, and shook, checked tightness of everything I can access. I have looked for shiny metal where something is moving around and found nothing. I get no vibrations, no bad steering issues or anything. It is like the tranny takes a bounce and lands back where it is suppose to be.
Also something else that might be related, occassionally when I take off and sort of lug it I get a banging / bucking feeling like slack in the drive line going back and forth...
Any ideas what could be loose or causing this, I just can't seem to locate it.
Thanks again folks, as always you people are great help...
HanksRide
(Hank is Yellow Lab) He loves it!!
95yj 4.0L, 4" RC Lift, 8.8, Aussie Locker, Posi-Lok, Rock Sliders, 1" Booms, 33 X 12.50's, Rhino Lining, KC Day Lighters, Rock Bumpers, LED Dash Lights, XRC10 Winch
HanksRide is offline
post #2 of 21 Old 08-17-2011, 07:55 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
How old is the trans mount? Have you put a jack under it to see if it is seperated?
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
post #3 of 21 Old 08-17-2011, 07:59 PM Thread Starter
HanksRide
You are talking about the single solid block tranny mount in the back of the tranny right?? No I have not, would I need to unbolt the skid plate or anything else first, or just put some pressure on it with a jack as is?? I did my own SYE a couple years ago and the mount looked good then but I know things can change.
HanksRide
post #4 of 21 Old 08-17-2011, 08:06 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Just put a little pressure on it with a jack and see if it's split. Also look to see if the t/c is close to the skid plate, a worn mount that is overly soft may cause the t/c to hit the skid plate on a bump.
5.7YJ is offline
post #5 of 21 Old 08-17-2011, 08:10 PM Thread Starter
HanksRide
Thanks 5.7, I will deffinitly check that stuff out... Appreciate the insight!!
HanksRide
post #6 of 21 Old 08-17-2011, 08:25 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Your very wecome, I hope it helps out.
5.7YJ is offline
post #7 of 21 Old 08-17-2011, 11:16 PM
MJMPC
Do you still have trac-bars hooked up?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #8 of 21 Old 08-18-2011, 06:05 AM
bogleparsons
since your checking mount check the engine mounts too, could cause "slack" when you first take off.
bogleparsons is offline
post #9 of 21 Old 08-18-2011, 08:04 PM Thread Starter
HanksRide
Nope no trac bars or sway bars installed.
HanksRide
post #10 of 21 Old 08-18-2011, 08:08 PM Thread Starter
HanksRide
I have visually checked them looking for obvious cracks, how else would I check for hidden defects, will jacking up on the tranny make this noticable as well?? It really doesn't make any noise on take off, more like if I lug it going slow in second gear, sort of a buck in drive line.. As stated before I notice the noise most of the time when going slow on a sub-par paved back road that maybe has a little dip in the road or when I hit the end of a bridge going really slow it sounds like something takes a bounce underneath it...
I didn't get a chance to check anything tonight, daughter is getting packed up to start college and took all my time this evening... Maybe tomorrow evening..
HanksRide
post #11 of 21 Old 08-18-2011, 08:23 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
The easiest way to check your engine mounts would be to have someone in the Jeep with the brake on, partialy let the clutch out in forward and reverse while you watch the mounts. If one or both is bad, you should see a lot of movement from the engine.
5.7YJ is offline
post #12 of 21 Old 08-18-2011, 08:37 PM Thread Starter
HanksRide
Thanks I will try that if what I have found did not fix it. I just went up and took a look under it and found I could wiggle my torque arm pretty easily by hand. It appeared to loose for me. I put a quick wrench on it and snugged it up... I did a visual on motor mounts and tranny mount and didn't see anything there that looked/felt loose or broken.. I am going to drive it to work tomorrow so I will no in about 1 mile if I did any good or not..
Still had good clothes on from going out to eat so didn't want to get to carried away tonight.. Reading about the torque arm got my curiosity up and I had to atleast go lay on the creeper under it for a few minutes..
HanksRide
post #13 of 21 Old 08-18-2011, 08:53 PM
t2timmy
Did you recently lift the jeep?? I had a similar issue once after I lifted mine the 2nd time, out of 3, and realized that the rear shocks were too short and bottoming out every once in a while. Took them off completely to test and sure enough, the noise was gone.
t2timmy is offline
post #14 of 21 Old 08-18-2011, 09:01 PM Thread Starter
HanksRide
No my lift is a couple of years old and installed shocks that came with lift.. The sound is a little different then that, not like a dead blow hammer hitting one spot but more like someone picked the front of the engine up about 2 inches and dropped it..
I don't believe it to be shocks but I certainly will not rule that out at this point..
HanksRide
post #15 of 21 Old 08-19-2011, 05:09 PM Thread Starter
HanksRide
I think tightening the torque arm may have fixed my problem. I drove it to work today and never heard the banging sound one time... How tight should the torque arm be?? I just snugged it up good with some wrenches but never actually torqued to anything specific... Will it work as it??
HanksRide
Another of those annoying "whats that noise" threads dadstoy YJ Wrangler Technical Forum 8 02-21-2011 09:23 PM
Can't Find This Noise!! HanksRide YJ Wrangler Technical Forum 6 03-15-2009 02:40 PM
Find my Pop/Noise (05 TJ) bonesnv TJ Wrangler Technical Forum 6 10-22-2008 12:09 PM
Can't find part with threads to secure windows (YJ, Half-steel doors) HELP! krautammi YJ Wrangler Technical Forum 9 11-15-2004 11:14 PM
please help me find this noise TonyTJ TJ Wrangler Technical Forum 3 11-27-2002 11:48 AM
