Another LS6 powered Jeep in CT *My Build* - JeepForum.com
post #1 of 28 Old 11-01-2010, 08:24 AM Thread Starter
TheMudSlut
1991 YJ Jeep Wrangler Z06
My Goal: To build an extreme dual purpose rig that can tackle the most technical woods trails and mud holes while still being a competent 1/4 mile stoplight racer.
Feedback and suggestions welcome.
Engine: 2004 Corvette Z06 405 HP (underrated)
Bought from an insurance company with just 8K miles in excellent cond
Bargain at just 4,600 with title and mileage verification.
FRONT AXLE: Rebuilt Dana 44 from wagoner with nitro axles + ujoints, Aussie lockers + 2" spacer
REAR AXLE: undecided, looking for best bang for the buck that can take over 400 hp beatings on the road while pushing 37" tires. Possibly a Ford 9" (open to suggestion)
Transmission: undecided, leaning to a new T56 6 speed Magnum from the dodge viper. Needs to be a fast shifting transmission NO 3 second delay between gears SM240/SM456 here!! (made that mistake once ) Second choice would be possibly the NV4500.
Stock Transfercase
Paint Options: Pumpkin metallic orange like seen on some lambos or neon srt4/ Signature WRX medium metalic blue/ Metallic Midnight purple
Body: CJ front grill, CJ hood, round flush mount LED brake lights, newer wide style fender flairs.
6.5 Rocky Road SOA kit + 3" body
Yet to buy 36-38" mudders
Looking to minimize the power robbing effect the big tires will have on my acceleration onroad. My idea is stick with the lightest tire/rim combo possible similar to the Jeep lower 40 with very large lightweight rims to minimize rubber weight. Also looking to go only 10.5" wide in front and 12 in the rear to reduce drag.
Saftey: Extensive roll cage built onto stock roll bars
Passenger and Driver leather racing seats with 4 point harness
Brakes: 2003 Ford F550 HydroBoost brake system MC+BB with retrofit mounting bracket to YJ firewall and pedal.
Electrical: Autometer phantom full guage set with tac and gps speedometer. Wideband A/F Ratio monitor, 150 watt KC Daylighters window mount P and D side
Frame completely sanded down & sealed from rust, coated with gloss black non texture bedliner paint.
Underbody has been cleaned & wirebrushed and professionally undercoated
Engine bay sprayed with black bed liner paint
Interior floors have been covered and sealed in bedliner with brand new black carpeting overtop.
Dual exhaust from headers into Y pipe with electric cut out then single 3" exhaust ran to the rear. Mid system has magnaflow 3" muffler and high flow cat with no tools quick disconnect V band flanges on each side to quickly replace with test pipe out to magnaflow muffler when desired.
Much more to come... including progress pics exc.
PROJECT IS 30% COMPLETE. ENGINE IS NOT INSTALLED YET AND STILL NEED TO FIGURE OUT DRIVETRAIN. Z06 Wranger is expected to be on the road within the next 3 months.
TheMudSlut is offline
post #2 of 28 Old 11-01-2010, 08:59 AM
grandboost98
thats absolutely awesome! i hope i see you around CT sometime to check it out
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #3 of 28 Old 11-01-2010, 09:23 AM
ssyj94
Sounds like an awesome build!
Id rethink the suspension/body lift though. The rocky road kit wont work since you wont be using stock axles. You'd be better off with say normal perchs, high steer, RE 1.5" soa springs, traction bar, decent shocks, 1" body lift and some tj flares or fender trimming.
My build:
ssyj94 is offline
post #4 of 28 Old 11-01-2010, 12:41 PM Thread Starter
TheMudSlut
RE: LIFT
Touchy subject because I know it's not good to have a high center of gravity but at the same time I still want the jeep to look big and bad. Hey, if big foot can pull it off why can't we? I am going to be running the same exact size body and suspension lift as another well known member on here with the first LS2 powered TJ, he also lives in CT. His LS2 in stock form puts out a few less ponies as does my Z06. Who knows? maybe we can meet up and get a good stoplight battle :: This is where I stole the whole idea from Even with the tall lift and 37's he seems to have no issues. He races it at the drag strip on the weekends and has no problem blowing donuts in the dirt without it wanting to roll over.
I know the rocky road kit won't fit the diameter of Dana 44's and larger but its nothing a little light fabrication could not fix. I also already bought the full kit from Rocky Road.
I was also thinking about removable front axle straps for onroad to keep the soft suspension from rocking back under hard acceleration and keep things stable.
Check out this guys videos on youtube!
YouTube - LS2 400hp V8 Jeep wrangler TJ driven for first time
YouTube - LS2 460HP V8 Jeep Wrangler TJ doing some donuts
YouTube - LS2 400hp V8 Jeep wrangler at the drag strip
post #5 of 28 Old 11-01-2010, 03:35 PM
kkchevy3
everytime it makes me depressed seeing the words 3" body lift on this forum.
kkchevy3 is offline
post #6 of 28 Old 11-01-2010, 04:32 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
I agree about the suspension about the amount of body lift, I don't know about the rocky road kit, but I don't think you need 3" of body lift along with a SOA to stuff 37's in there. 1" body lift with TJ flares will help you on your COG. I am not a big fan of anything over a 1" body lift.
Great plans and that thing will scream. make sure to post alot of pics of the build.
To view the NEW
click here!!!
tobias94yj is offline
post #7 of 28 Old 11-01-2010, 09:11 PM
ssyj94
I wouldnt worry about rocking back under hard throttle and the cog could be ok with a little width/stretch. The problem will be the stock leaf springs soa wont work well mine wraps up some with a traction bar and a 4.0L. The difference with the guy with a tj is he has a RE long arm coil lift and you are using leaf springs that will wrap like spaghettio's with that amount of torque. I'd just sell the rocky road kit and buy long universal perches that will fit the axles you buy. For the rear axle I'd go 1ton without a doubt.
My build:
ssyj94 is offline
post #8 of 28 Old 11-02-2010, 11:16 AM Thread Starter
TheMudSlut
Okay, if I buy perches and do the SOA without lift how much higher would it be then the stock SUA? About 1.5"? What are some common cheap 1 ton axles? Would that be like the ford 8.8 from a F series v8?
Can I still use my shocks I bought with the RR 6.5 SOA kit? Should I get the same articulation as the RR kit but just without any lift?
post #9 of 28 Old 11-02-2010, 11:23 AM
TheNewbie
No, SOA alone (with stock height springs) will get you about 5.5" of lift.
The suspension setup that you have listed will net you about 9.5" of lift. That's just crazy tall. If you want to be running 4 foot tall tires then I think you're on the right track.
About 6.5" would get you into 38" tire range without cutting.
If a 4" lift will run 33's, your 38's (5" taller) will need 2.5" more clearance since 1/2 of that extra 5" is under the wheel. So about 6.5" with some TJ flares and of corse the right bump stops will be plenty. That extra 3" will do nothing but cause you to tip over and roll a lot more easilly.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #10 of 28 Old 11-02-2010, 09:02 PM
ssyj94
Do some researching it'll clear up most of your questions. Look in the faq about SOA.
Forget the whole RR soa stuff and just sell it. SOA(spring over axle) provides 5"-6" of lift with a stock spring once you get it done measure for shocks you'll be changing the stock mounting locations most likely anyways. The reason I suggested the RE 1.5" SOA springs is due to thier superior ability to deal with axlewrap since they have more arch than stock springs.
An 8.8 is a 1/2 ton pickup rear end like the waggy 44 front you want to run. A common 1ton rear is a 60, 70, and14bolt.
My build:
ssyj94 is offline
post #11 of 28 Old 11-05-2010, 07:43 PM Thread Starter
TheMudSlut
I think I am going to have a set-up VERY similar to the Jeep lower forty. That thing is AWESOME looking. It has 390 HP V8 40 inch tires with 20 inch rims. I will have over 400hp probably 20 inch rims on 37's. That also uses a D44 front and D60 rear like I plan. I am very curious to find out the 0-60 and 1/4th mile on the lower forty but nothing has been published yet. I am also curious to know what the axle length is but I cannot find that either. I have decided to lean on the side of on-road performance. I am considering heavy duty springs to enhance cornering ability and steering feel but I suspect that would limit my articulation?
I also want to do a plexyglass hood window like the ZR1 corvette has to showcase the beautiful engine. I have a CJ hood so I will have to figure something out on custom fab. That is all for now. Feedback and ideas welcome.
post #12 of 28 Old 11-05-2010, 09:05 PM
ssyj94
Time to look into 3link front/4 link rear with coilovers.
My build:
ssyj94 is offline
post #13 of 28 Old 11-06-2010, 09:42 AM Thread Starter
TheMudSlut
I may do it if it is necessary but I would rather spend the money elsewhere if I could or do it later down the road. This is my idea of getting similar results for alot less money and labor.
I was thinking of using adjustable leaf spring helpers to dial in the suspension stiffness using stock springs with SOA combined with some nice extreme duty remote res shocks with a broad range of adjust ability & track bars. This way I could change the settings to a stiff ride onroad to a soft ride offroad still with acceptable articulation.
After all, even the most expensive corvettes still use leaf springs in the rear and they have higher cornering limits then supercars doubble and tripple their price tag
post #14 of 28 Old 11-06-2010, 09:58 AM Thread Starter
TheMudSlut
Axles?
Hey, what's the deal with the stock D44 axles? Everyone on here states they will not support anything larger then 35's without breaking even using the stock 190HP motor. They also say that even stock 60's won't support anything over 37's with a 190hp motor on open diffs.
Then the Jeep team rolls out with the new Lower Forty jeep with 390HP AND 44 inch tires WITH lockers useing a.... get this.... DANA 44 IN FRONT!!!?? According to consensus on the forum 60's could never support 44's let alone with LOCKERS and 390 HP! You would expect from what you read on the forum that the jeep lower forty would almost instantly snap the front axle the first time the power was applied offroad but the jeep performance engineers seem to disagree. Am I missing something?
post #15 of 28 Old 11-06-2010, 04:21 PM
TheNewbie
Yeah, but there's a big difference between driving back and forth to car shows and applying 400+ HP to a single wheel that is WEDGED in between a couple huge unmovelable rocks.
400 HP plus tires that size will probably be capible or breaking most any setup in an extreme off road scenario. But it sounds like you mostly plan on impressing a few buddies at the trank and car show yourself so I wouldn;t worry about it all that much.
Now if you really want this thing for it's off road capibilities... the 400 HP motor is really not going to add all that much. Let's face it, this rig isn't about getting to places that nobody else can, because you could build a rig that could do that with the stock 2.5 and some axel gearing.
anyone done a grand national powered jeep lloydsmale TJ Wrangler Technical Forum 11 01-09-2012 04:16 PM
Pentastar Powered JK, 5 speed tranny and new full size Jeep truck! Jeeprin JK Wrangler Technical Forum 14 09-18-2010 09:46 PM
my friends cummins 6bt powered jeep cheapjeeps85 YJ Wrangler Technical Forum 56 11-05-2009 05:58 AM
Under Powered YJ Blue90YJ YJ Wrangler Technical Forum 11 12-13-2006 11:12 AM
Ethanol Powered Jeep trapman TJ Wrangler Technical Forum 3 10-17-2006 02:14 PM
