Another leak. - JeepForum.com
post #1 of 6 Old 09-16-2011, 09:29 PM Thread Starter
Collin89Sahara
Another leak.
What causes leaks on the passenger side footwell?
Collin89Sahara is offline
post #2 of 6 Old 09-16-2011, 10:24 PM
moonshinefuel
Heater core usually.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 6 Old 09-16-2011, 10:31 PM
GottaYJ
^^^If its coolant. If its water clear your cowl drain tube on the firewall
1995 YJ Rio Grande 2.5L
GottaYJ is offline
post #4 of 6 Old 09-16-2011, 10:40 PM Thread Starter
Collin89Sahara
It's only when it rains. My carpets get soaked, and behind the passenger seat as well. I am very perplexed. Any ideas guys?
post #5 of 6 Old 09-17-2011, 10:12 AM
moonshinefuel
There is a 1.75 rubber line hose on the firewall, it is a drain hose that has been known to get clogged with debris. Remove it, was it out, its probably clogged. Also wash water down through the grill in front of the windshield with hose removed to wash out any extra debris that may be accumulated in there.
Bow Hunting
post #6 of 6 Old 09-17-2011, 11:02 AM
mike_breaker_5
drop your windshield and look at the condition of your seal and the WS frame itself. if your seal is all hard and nasty it will let rain in (mine leaked on the drivers feet). if the WS frame is all rusted up the same thing can occur (mine was toast aswell). also the section of the tub under the WS frame could be rusted aswell, just another thing to check.
may be a good idea to look under there anyway if you have never had the windshield down. if you have the beginnings of rust under there it wouldn't take long to spread. the water that gets pushed in there at driving speeds stays in there and wreaks havoc on anything that has just a little rust on it.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
Pinhole leak in radiator--Alumaseal/Bar's Stop leak? JEEP97TJ TJ Wrangler Technical Forum 16 06-11-2010 07:01 PM
New jeep owner! (exhaust leak and oil leak) Mindcrime13 TJ Wrangler Technical Forum 9 03-04-2010 02:34 PM
Engine oil leak! Front diff sweatl leak Mr.Unlimited JK Wrangler Technical Forum 11 09-22-2009 09:49 PM
Tranny Leak, any common place for a jeep to leak jb1dsl TJ Wrangler Technical Forum 6 03-23-2006 11:09 AM
rear main seal leak and exhaust leak? paroxysym TJ Wrangler Technical Forum 6 01-30-2006 01:46 PM
