Another Ignition Module Failure Thread - JeepForum.com
post #1 of 9 Old 02-12-2013, 08:32 AM Thread Starter
Renegad87
1987 YJ Wrangler
First off I've read almost every post I came across on this topic and haven't seen anyone with my experience so I'm starting a new thread.
4.2L
Nuttered
Weber
JuiceBox Ignition Upgrade
I burned up my first ignition module yesterday while "rescuing" my girlfriend's car from the woods she drove through. Icy roads and sharp turns don't mix.
All the upgrades listed above have been running for over 2 years with no complaints.
Jeep died while I was away from it and sat with ignition ON for a few minutes before I got back to it. Came back and it wouldn't start. I tried cranking for a few, but didn't get anywhere and then smelled the fatal electrical fire smell I'm sure we are all familiar with.
Opened the hood and let the wonderful smoke roll out. Ignition module was still cooking even with the key off. I had to disconnect the battery for it to stop.
So I replaced the module and it's been running fine. My question is did this just happen to fail that day or is something else wrong?
Renegad87 is offline
post #2 of 9 Old 02-12-2013, 08:46 AM
Que89YJ
Try this:
http://www.squidoo.com/jeep-tfi-team-rush-upgrade
Avoid Burning Up Your Coil With A Ballast Resistor
Que89YJ is online now
post #3 of 9 Old 02-12-2013, 11:07 AM
Old4X
1990 CJ7
If the ignition is left on (not running) with these ignition systems, they will burn up in less than a minute. Even a new module.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #4 of 9 Old 02-12-2013, 07:15 PM Thread Starter
Renegad87
1987 YJ Wrangler
Old4x
I was wondering about that. I had always been told that leaving the ignition on without the engine is running was bad, but I never really understood it. So for now unless it happens again I will write this off as leaving the ignition on burned up my ignition module.
Que89yj
Excellent site I definitely bookmarked it. If I every have a coil problem I'll look into adding a resister and come to think of it I may run out this weekend and check the voltage at my coil.
post #5 of 9 Old 02-12-2013, 09:49 PM
Old4X
1990 CJ7
Are you using a Duraspark style module?
Old4X is offline
post #6 of 9 Old 02-13-2013, 01:56 PM Thread Starter
Renegad87
1987 YJ Wrangler
I'm using one of these. I bought it at NAPA. I think it was labeled TP-40
post #7 of 9 Old 02-13-2013, 03:53 PM
yellow2kgt
Another thing to check, are you still using the factory resistance wire to power the coil? Running a full 12 volts to it could also end in premature icm failure.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #8 of 9 Old 02-13-2013, 04:29 PM
Old4X
1990 CJ7
That is the duraspark style. Remember to turn ignition off when not running the engine. No radio playing when parked except in accessory position.
You can do the GM ICM mod if you keep having problems. Those ICMs are much better than the duraspark, and are internally regulated, they do not run an external resistor, that means hotter spark at idle. Only $25, most with a lifetime guarantee.
Old4X is offline
post #9 of 9 Old 02-13-2013, 07:22 PM Thread Starter
Renegad87
1987 YJ Wrangler
Old4x
Excellent thanks for the info. If this one burns up within the next year I'll go with a GM ICM mode. I already started looking at it. Jeep is getting rewired this summer so I may add it to the list.
Yellow2kgt
I performed the nutter bypass and ran new wire from the ignition module to the coil so I'm going to guess and say that I am not using the resistance wire originally used. I'll have to pull out the diagrams and figure out which one that is. I hate all these "fusible links" and "Resistance wires" this summer they are all getting replaced with modern components. Checking the coil voltage is at the top of my list once the snow stops falling.
