Another Hand Throttle Write Up - JeepForum.com
post #1 of 9 Old 02-17-2009, 06:45 PM Thread Starter
Blazin Den
I went and ordered the RE Hand Throttle Kit and installed it this weekend. I know the pics are big but i did it that way in case any one needed a close up of what i did.
Start of the Project
Pilot Hole Drilled For Bracket
Next Is to find a spot of the fire wall to run the cable. I went right under where the wires are comin out on the firewall. The red wire is for my fuse box that installed to run other stuff like cb, lights, etc.
Now go to the inside. Take off you shift knob, and put the Hand throttle on where you want it. Take the cable and cut one of the ends to slide the cable through the casing. Make sure you cut the right end.
I have the cable running down the shifter, along the floor, up the firewall and then going to the engine bay.
I routed the cable behind the big wire harness on the firewall and around to on top of the vavle cover where the cruise control cable would go.
Now go out to the engine bay and mount the bracket for the hand throttle.
I originally had the bracket like this but switched it to the look like in the 2nd pic. You cant really see it but it in one the inside instead of the outside.
Now instead of wrapping the wiring around the knob opposite of the throttle cable where the cruise control would be and crimping it i stopped by the junk yard and cut a throttle cable on an XJ and used the black plastic end end off of it. I pulled the cable tight and put the crimp on the end of the black piece. This fits right on the knob and will not slip off.
To show you what i mean here is the yj return spring and the end off the xj.
Finished
i look at a couple writeups before i did mine and here they are. there are more out there but i used these ones.
http://www.4x4xplor.com/handthrottle.html
http://personalpages.tds.net/~larsonj/HandThrot.htm
http://www.nakedjeep.com/Projects/Ha...hrottle01.html
95 White YJ 2.5L/AX-5 Stock on 31s. Ground Pounder Fab (BESRK) Front Bumper, Herculined Interior, Windshield/Front Bumper Mounted Lights, Uniden PRO 520XL Cb,Hidden Hitch Trailer Hitch, Bestop Supertop, Modified CJ7 Hardtop and CJ7 Twist Handle Full Doors (winter)
Blazin Den is offline
post #2 of 9 Old 02-17-2009, 07:10 PM
heep1991
The more I see this the more I want to install on my Jeep.. great write up
1991 YJ 2.5L - SOLD
2006 Jeep Commander 6cyl - SOLD
2007 Jeep Unlimited Rubicon 3.8L
heep1991 is offline
post #3 of 9 Old 02-17-2009, 07:49 PM
tnachidester
Very interesting. I have never herd of useing a hand throttle and was woundering what the advantages are?
tnachidester is offline
post #4 of 9 Old 02-17-2009, 07:54 PM
Rustbucket83
I used mine to rev up the engine and build more air pressure for OBA system while using impacts and such.
Rustbucket83 is offline
post #5 of 9 Old 02-17-2009, 09:06 PM
titoheadfaceman
Nice! I put mine in the same position on the shifter. Works great as a cruise control. The only difference was I ran mine down through the shifter boot to the outside underneath, ran it alongside other lines in the transmission tunnel, and then up the the throttle body.
titoheadfaceman is offline
post #6 of 9 Old 02-17-2009, 09:13 PM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
Man. I guess when i figure out how to rig mine.. ill make a write up.. for us carbed guys.
Thomas
-1987 YJ
Tompatt is offline
post #7 of 9 Old 03-03-2010, 10:15 AM
90jeepyj09
ya i need to figure out how to hook that up to the carb also
[]llll[] ---- "Pain Heals. Chick Dig Scars. Glory Lasts Forver"
HARDTOP FOR SALE:
Originally Posted by JDNightFox View Post
Obviously, you haven't taken Physics.
The terminal velocity of the square headlights is directionally preportional to the force of gravity decelerating the front wheels while the alternator is spinning at 3000 rpm's, minus the friction of the bumper pushing against the airflow with the 13 volt current the steering column is using during the time the vacuum motor is disengaged, but the mirrors must be directionally angled from the driver's window because the hood latches deflect the light refractioning down through the Nitrogen coat on the hood.
90jeepyj09 is offline
post #8 of 9 Old 03-03-2010, 06:42 PM
timatoe
timatoe's Avatar
I built my own hand throttle. I have the Howell TBI kit, but I hooked it up to stock parts, so it would still work with the carb. I'm headed off to work shortly (I work graveyard shift), shoot me a PM and I'll try to get you some pics in the next day or two.
timatoe is offline
post #9 of 9 Old 09-25-2011, 06:12 AM
tommbstone
wow over a year later and still no pics of your tbi hand throttle. tisk tisk tisk
I want to do this once I get my tbi running correct. If you can put the pics up I'd appericate it bro. Thx
tommbstone is offline
Hand Throttle Tradewinds YJ Wrangler Technical Forum 8 03-19-2009 12:45 PM
Hand throttle write up with pics! jeepbub08 YJ Wrangler Technical Forum 61 02-21-2009 02:48 PM
Why use a hand throttle? TJoshX Wrangler General Discussion 16 09-20-2008 05:40 PM
Hand throttle Bobtail Bob TJ Wrangler Technical Forum 9 01-11-2008 09:53 AM
Hand Throttle zaq123 TJ Wrangler Technical Forum 45 03-28-2006 03:39 PM
