-   -   Another Hand Throttle Write Up (http://www.jeepforum.com/forum/f12/another-hand-throttle-write-up-697579/)
Blazin Den 02-17-2009 06:45 PM
I went and ordered the RE Hand Throttle Kit and installed it this weekend. I know the pics are big but i did it that way in case any one needed a close up of what i did.
Start of the Project
http://i248.photobucket.com/albums/g...J/DSCN1756.jpg
Pilot Hole Drilled For Bracket
http://i248.photobucket.com/albums/g...J/DSCN1757.jpg
Next Is to find a spot of the fire wall to run the cable. I went right under where the wires are comin out on the firewall. The red wire is for my fuse box that installed to run other stuff like cb, lights, etc.
http://i248.photobucket.com/albums/g...J/DSCN1758.jpg
Now go to the inside. Take off you shift knob, and put the Hand throttle on where you want it. Take the cable and cut one of the ends to slide the cable through the casing. Make sure you cut the right end.
I have the cable running down the shifter, along the floor, up the firewall and then going to the engine bay.
http://i248.photobucket.com/albums/g...J/DSCN1761.jpg
http://i248.photobucket.com/albums/g...J/DSCN1759.jpg
http://i248.photobucket.com/albums/g...J/DSCN1762.jpg
http://i248.photobucket.com/albums/g...J/DSCN1763.jpg
I routed the cable behind the big wire harness on the firewall and around to on top of the vavle cover where the cruise control cable would go.
http://i248.photobucket.com/albums/g...J/DSCN1760.jpg
Now go out to the engine bay and mount the bracket for the hand throttle.
I originally had the bracket like this but switched it to the look like in the 2nd pic. You cant really see it but it in one the inside instead of the outside.
http://i248.photobucket.com/albums/g...J/DSCN1765.jpg
http://i248.photobucket.com/albums/g...J/DSCN1768.jpg
Now instead of wrapping the wiring around the knob opposite of the throttle cable where the cruise control would be and crimping it i stopped by the junk yard and cut a throttle cable on an XJ and used the black plastic end end off of it. I pulled the cable tight and put the crimp on the end of the black piece. This fits right on the knob and will not slip off.
To show you what i mean here is the yj return spring and the end off the xj.
http://i248.photobucket.com/albums/g...J/DSCN1764.jpg
Finished
i look at a couple writeups before i did mine and here they are. there are more out there but i used these ones.
http://www.4x4xplor.com/handthrottle.html
http://personalpages.tds.net/~larsonj/HandThrot.htm
http://www.nakedjeep.com/Projects/Ha...hrottle01.html
heep1991 02-17-2009 07:10 PM
The more I see this the more I want to install on my Jeep.. great write up
tnachidester 02-17-2009 07:49 PM
Very interesting. I have never herd of useing a hand throttle and was woundering what the advantages are?
Rustbucket83 02-17-2009 07:54 PM
I used mine to rev up the engine and build more air pressure for OBA system while using impacts and such.
titoheadfaceman 02-17-2009 09:06 PM
Nice! I put mine in the same position on the shifter. Works great as a cruise control. The only difference was I ran mine down through the shifter boot to the outside underneath, ran it alongside other lines in the transmission tunnel, and then up the the throttle body.
Tompatt 02-17-2009 09:13 PM
Man. I guess when i figure out how to rig mine.. ill make a write up.. for us carbed guys. :D
90jeepyj09 03-03-2010 10:15 AM
ya i need to figure out how to hook that up to the carb also
timatoe 03-03-2010 06:42 PM
I built my own hand throttle. I have the Howell TBI kit, but I hooked it up to stock parts, so it would still work with the carb. I'm headed off to work shortly (I work graveyard shift), shoot me a PM and I'll try to get you some pics in the next day or two.
tommbstone 09-25-2011 06:12 AM
wow over a year later and still no pics of your tbi hand throttle. tisk tisk tisk
I want to do this once I get my tbi running correct. If you can put the pics up I'd appericate it bro. Thx
The time now is 08:48 PM.
