Another frame swap, then build thread - Page 8 - JeepForum.com
post #106 of 141 Old 01-19-2013, 07:48 AM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Originally Posted by soonermatt View Post
Just a reminder to try the UV protector on that Herculiner. It degrades quickly in the sun. In my build thread I have to switch to Monstaliner due to the fading.
Is the UV protection made by herculiner? Never seen it. Or are you talking another brand
EDIT: Disregard. I found it thru Amazon.com... Why the autoparts stores don't sell it next to the liner is beyond me...
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #107 of 141 Old 01-19-2013, 07:50 AM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Originally Posted by Louie4 View Post
Looking great. I need to relocate my bump stops as well. Did you just drill new holes an inch or two forward and put the same screws in the frame?
Under heavy compression my drag link will contact the frame and my extended bumpstops are not lined up due to the pushing forward of the axle.
Yup. Redrilled and tapped the holes and used same bolts...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #108 of 141 Old 01-19-2013, 11:34 AM
soonermatt
I'll be curious if the protector works. It faded quickly inside my tub without it.
soonermatt is offline
post #109 of 141 Old 01-19-2013, 02:15 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Took her for a test drive today thru the neighborhood...As is seen below... Got a few odd looks...
Oil change just because.
Rear shocks arrived just as I was finishing up for the day..
Ordered some UV protectant for the herculiner
put all my S@#$ back into my tuffy boxes..
The end is soooooo close!
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #110 of 141 Old 01-21-2013, 07:48 AM
Louie4
That's awesome. I just got back from another 500 mile round trip excursion with the jeep. I think it's going to take a break though for the next couple months while I make some much needed repairs.
What tap size did you use for the frame on the bumpstop extensions?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #111 of 141 Old 01-21-2013, 09:10 AM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Itis a 5/16 18 thread.. I was going to use some #10 x 1 hex head self tapping but ran out...Tapping is better anyhow..
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #112 of 141 Old 01-25-2013, 01:49 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Brown truck came witht he final pieces of the frame swap/rebuild.
Fuse relay box...
and 8.8 clutch pack to tighten her up...I never replaced the originals when I installed the axle
and Herculiner UV protectant
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #113 of 141 Old 01-25-2013, 01:54 PM
responder
Nice relay/fuse block! Did I miss where you ordered that from?
responder is offline
post #114 of 141 Old 01-25-2013, 02:01 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Nope...I didn't post it... Its the same block that Anti got from IH8 Mud, who no longer makes them... How he did it for $100 is beyond me....
I found them thru a web search on Alpine Sand Toys. a UTV site...
He has them made for him by Concourse speacilties.
AST has been very slow thru the whole process... While trying to track down the fuse box and tracking # after the order was placed, I got next to nothing from AST, so I email Concourse direct and he responded right away. He doesn't list them on his web site, but I'd still try him direct if you are interested.
After all the work I've done, I couldn't have the massive $35 JY relay set up I made. This is worth the....drum roll.......$229 I paid...
Greg
Concours Specialties
greg@teamconcours.com
513-481-9999
www.teamconcours.com
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #115 of 141 Old 01-25-2013, 03:06 PM
schaef89
I've been following since the first post and I must say this is impressive!
One question I have is how much the UV protectant set you back?
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #116 of 141 Old 01-25-2013, 03:14 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Thanks..
Amazon.com $24
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #117 of 141 Old 01-25-2013, 05:37 PM
soonermatt
I'll be curious if those clutch pack makes a difference. I've abandoned my limited slip altogether and don't even add friction modifier any more.
I'd be interested to hear if the packs help.
post #118 of 141 Old 01-25-2013, 07:54 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Currently no issues w mine but they are the originals. I'm going to add an extra disk or 2 and see how it tightens up... add enough and almost get a spool. I'll let you know.
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #119 of 141 Old 01-26-2013, 07:12 AM
soonermatt
Do you use friction modifier too? I've stopped but am not sure if it's good or not.
post #120 of 141 Old 01-26-2013, 08:58 AM
navman
The friction modifier actually helps it slip just a little to reduce noice and shock. Not using it actually makes it slip a little less. The frictions will wear faster overall but not a big deal.
95 YJ 5.0 linked etc
navman is offline
