Another frame swap, then build thread - Page 5 - JeepForum.com
post #61 of 141 Old 12-17-2012, 06:03 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
More parts!! DS rotor kit!
I think I have everything that need to go on before the tub...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #62 of 141 Old 12-19-2012, 05:39 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Figured while I have easy access to the T case, I ordered the Tera Low 4:1 kit w 2WD low
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #63 of 141 Old 12-22-2012, 03:17 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Puttered a bit today... Got the fuel tank back in and ran the lines. Needed to relocate the fuel filter due to the new shock configuration. Seeing how I'm going with a shaft parking brake, I don't really need the parking brake cables. I ran the filter and fuel line thru the bracket that use to hold the rear parking brake lines... I'll still run them to the same area so if some one looks quick, it'll look like they work (state inspection)
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #64 of 141 Old 12-22-2012, 03:24 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Also mounted the durango steering box and the steering box relocator.
New 136 amp alternator and my 150 amp alt cable kit arrived too. Nice kit, includes 150 amp fuse and gounds cables and I ordered additional cables for my dual batteries and ungraded starter leads...
Came from http://ceautoelectricsupply.com/alte...ationkits.html Arrived today, ordered 48 hrs ago and kit is made to order...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #65 of 141 Old 12-26-2012, 01:13 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Pulled the T case off, an apart, Hopefully my 4:1 will be here in a day or so...
Ran the gas tank vent line,
Changed the trans oil....minimally milky....
And replaced that bushing that goes under the shifter on top of the trans...the old one was almost non exhistant.
One I get the tcase back in the tub can go back on...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #66 of 141 Old 12-28-2012, 05:07 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
BBT came. (big brown truck)
My Terra 4.1 kit, some electrical stuff for my taurus fan and a rear tube for the roll bar...
Unfortunately, I've got plans all weekend, but come Monday, If I get the 4.1 in then I can get the tub back on....
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #67 of 141 Old 01-01-2013, 05:28 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Assembled the tera 4.1 kit.
Installed the T case
Installed the rotor kit
Installed drive shaft
Great customer service from Tom Woods. Had to send the shaft back so they could swap out the CV Yoke to aflange for the rotor kit. Had new uni joints installed, and the put a new boot and fresh coat of paint on it too.
Was hoping to get the tub on tomorrow but its suppose to be Fing cold out w a nasty wind chill. Since the tub is in the yard, guess it'll wait a day or two
T case4.1a.jpg   rotor kit install.jpg   rotor kit installa.jpg   shaft.jpg   drive train.jpg
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #68 of 141 Old 01-01-2013, 06:48 PM
sdotcarter
Looking friggen good.
Can you tell me what the rotor kits good for?
sdotcarter is offline
post #69 of 141 Old 01-01-2013, 07:49 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Good for, or Go for?
http://www.4xshaft.com/index.html $390
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #70 of 141 Old 01-01-2013, 08:21 PM
craniumboy
Never seen that rotor kit. I want one soooooo bad now. That is awesome.
Keep on Jeepin' on!
craniumboy is offline
post #71 of 141 Old 01-03-2013, 03:50 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Got the tub back on the frame... Fought me the whole way. Found two rotted body mounts on the tub. (I knew one was soft) the driver rear and passenger front.
Back into the garage on the frame. Jacked up one side and fixed the rear one already.
I've skidded logs but this is the first time I've skidded a jeep...
Sure looks good, sitting on the clean frame.
The rotor brake was my only concern for clearence. The edge catches the muffler heat shield. Nothing some tin snips can fix...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #72 of 141 Old 01-04-2013, 07:16 AM
responder
It's really coming together nicely now! Looking good.
responder is offline
post #73 of 141 Old 01-04-2013, 07:36 AM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Thanks...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #74 of 141 Old 01-05-2013, 04:24 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Fixed the rotted passenger front body mount area.
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #75 of 141 Old 01-06-2013, 09:25 AM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Pulled the battery tray, in prep for dual battery set up
SOLD
YJOTM FEB 2013
NHfireLJ is offline
