Another frame swap, then build thread - Page 4 - JeepForum.com
post #46 of 141 Old 12-08-2012, 11:25 AM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Ordered:
Steering box relocation bracket
Steering bok lines
Steering shaft
Browndog super brackets
Rotor kit (shaft parking brake)
and a pile of misc items
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #47 of 141 Old 12-08-2012, 11:58 AM
sdotcarter
Envious.
Are you also going to be applying a protective coating to the underside of your tub since your doing the frame?
sdotcarter is offline
post #48 of 141 Old 12-08-2012, 12:06 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Originally Posted by sdotcarter View Post
Envious.
Probably just the rustoleum can spray under coating
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #49 of 141 Old 12-08-2012, 08:05 PM
sdotcarter
I had a old Geo tracker that I did with primer then the cheep rubberized undercoating. Held up for two northern Maine winters before I sold it. Maybe you want to consider that route for added protection.
post #50 of 141 Old 12-09-2012, 01:51 AM Thread Starter
NHfireLJ
NHfireLJ's Avatar
thats the rustoleum I'm talking about!
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #51 of 141 Old 12-09-2012, 03:24 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Finally got a second set of hands, So we got the engine off the old frame,
Cut off the engine mount pylons, Swapped the axles , and mocked the engine into the new frame... Mounts are tacked in place...
engine swap (1).jpg   engine swap (2).jpg   engine swap (3).jpg   engine swap (4).jpg   engine swap (5).jpg
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #52 of 141 Old 12-09-2012, 03:28 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Here is the reason for the frame swap. You can see all the patches and holes. Not including the rear sections I did 4 years ago!
BTW the rear frame sections and the factory shock mounts are for sale. They are in great condition.
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #53 of 141 Old 12-09-2012, 08:51 PM
wanabejeeper
1987 YJ Wrangler
The reason I asked about the welder was I have a lincoln 135 from HD and I wasn't sure if it would be up to the taks of welding on the fram. I have some pieces of scrap steel I set aside both thin 18 and some 1/4 inch stuff to practise on. Its good to know that it will be able to do what I need.
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #54 of 141 Old 12-09-2012, 08:53 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Should work fine!
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #55 of 141 Old 12-12-2012, 03:42 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Parts slowly arriving.
New rear bump stops, D30 yoke ubolt conversion, parts Mike steering box relocation
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #56 of 141 Old 12-13-2012, 02:57 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Look what arrived!!! Tomorrows project, so I can hoist the motor for the last time...Install the brackets, finish welding the pylons, and then I can get the second coat paint done, along with the eastwood inside frame coating done...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #57 of 141 Old 12-13-2012, 03:04 PM
Fuddmaster
Those are beautiful!! Have fun!
Fuddmaster is offline
post #58 of 141 Old 12-14-2012, 02:06 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Mounted my Brown dog super brackets.....Finished welding the pylons and gave her a second coat of paint....External and internal...The Eastwood stuff is the nuts..The sprayer hose does a decent job. Even when I was mid frame the mist was coming out the rear...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #59 of 141 Old 12-14-2012, 02:07 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Oh yeah. Prepped the old frame for travel
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #60 of 141 Old 12-14-2012, 03:24 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Picked up more parts.
Durango 136 amp alt and durango steering box. Damn this thing is beefy!
I had picked up a used alternator 136 amp, and it matches the part number for the swap, but this one is internally regulated (top one) so can't use it... Decided new was a better choice considering almost everything else under the hood is or will be..
SOLD
YJOTM FEB 2013
NHfireLJ is offline
