Another frame swap, then build thread - Page 3 - JeepForum.com
post #31 of 141 Old 12-04-2012, 01:59 PM
Peter Nuss
1987 YJ Wrangler
If that rear shock mount is finished, you might want to reconsider it. You've got more twisting leverage and stress with that design than can possibly last.
Peter Nuss is offline
post #32 of 141 Old 12-04-2012, 03:46 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I agree. The force point is pretty far inward, so the forces are not all up/down as you would expect. It will probably work, since the forces are shocked obviously, not sharp.
That thinking is why the base of the shock bolt of my setup does not stick out away from the frame much at all, less than 1/2". (Sorry for the negative comments, but it is one of the side effects of posting a photo... )
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #33 of 141 Old 12-05-2012, 11:01 AM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Not sure how you figure... The location matches the factory mount except 1 3/4" taller and 1" forward of the factory location. The upper bolt location is 1 1/2" inward from the frame as the factory mount was, so laterally its the same .
If you recall the MORE brackets only get bolted to the stock location w/ a single nut, and in that application they are substaintially more inward, and there is nothing securing the bottom, just a pin to prevent rotation..
EDIT: Don't get me wrong. I appreciate the comments pos and neg... I just don't see 3/8 steel gusseted mounts in a similiar to factory set up twisting
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is online now
post #34 of 141 Old 12-06-2012, 03:30 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Busy day...
Picked up an 2T engine hoist for $100 bucks, new condition.
My rear bumper frame tie ins from Bezerk arrived so I got them welded in..
SOLD
YJOTM FEB 2013
post #35 of 141 Old 12-06-2012, 03:32 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Started the tub/body tear down..
teardown (1).jpg   teardown (3).jpg   teardown (5).jpg   teardown (6).jpg   teardown (7).jpg
SOLD
YJOTM FEB 2013
post #36 of 141 Old 12-06-2012, 03:36 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Screech.......Put on the brakes... So I was told this was a 4.0 frame... It wasn't until I drove 2 hrs that I was told it was a 2.5, converted to a Chevy and back to a 4.0. It last had a 4.0 under the hood... Well now that I can see my engine pylon mounts clearly, the new frame pylons are over an 1" to 1 1/2" off!!! Looks like I'll be cutting the pylons off.... Just ordered new frame pylons from Mopar parts!
SOLD
YJOTM FEB 2013
post #37 of 141 Old 12-06-2012, 07:02 PM
JeeperDon
JeeperDon's Avatar
I forgot. I was lucky to have a buddy help me, and he had a car hoist, which easily held the tub while we did the rest. My swap took one 2.5 day weekend. It was really nice to get new fuel and brake lines, even some wiring replaced, not just a new frame.
Web Admin for
post #38 of 141 Old 12-06-2012, 07:19 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
The brake line on my old frame are less than a year, the fuel line from the new frame are pristine... And I'm going to do a major wiring clean up as I put it all back together...as well as the following
durango sterring box and probably a new steering shaft
marquis master cylinder w/ a grand cherokee all disk proportionig valve
New shocks x 4 (due to the longer shock mounts) Bilstens 5100 maybe. Open to sugestions
Going to make a dual battery tray
135 amp alt. Already have a GC one.
Electric fan (ford taurus).
Parts mike Rotor kit (drive shaft brake)
SOLD
YJOTM FEB 2013
post #39 of 141 Old 12-07-2012, 06:49 AM
Fuddmaster
Subscribed!! I'll be doing a rebuild/ motor swap (v-8)/ everything upgrade lol at some point. This will help me get my frame squared away!
Fuddmaster is offline
post #40 of 141 Old 12-07-2012, 08:04 AM
wanabejeeper
1987 YJ Wrangler
What type of welder are you using... those are nice looking welds.
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #41 of 141 Old 12-07-2012, 10:13 AM
JeeperDon
JeeperDon's Avatar
Welders don't make good welds, welders do.
Web Admin for
post #42 of 141 Old 12-07-2012, 12:00 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Its a Homedepot Lincoln 110V mig. It has the gas option but I just use flux core wire. One of these days I'll hook up the gas..
Best $350 spent... You can do up to 1/4" with practice...
SOLD
YJOTM FEB 2013
post #43 of 141 Old 12-07-2012, 02:11 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Bad news on the Frame to engine pylons... No longer available..
Looks like I'll be cutting the ones off my old frame and rewelding them to the new... ARGH
Good news: my Eastwood internal frame paint came....Oh yeah can't use it till I'm done welding. DOH.
SOLD
YJOTM FEB 2013
post #44 of 141 Old 12-07-2012, 02:14 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Removed the tub...By myself.... Sorta sucked. My driveway is sloped too...
Only scratched the tailgate. Forgot one airhose in the process too, but made frequent checks as the tub came up....
I will definately want a few more hands to put it back on...
SOLD
YJOTM FEB 2013
post #45 of 141 Old 12-07-2012, 02:28 PM
Fuddmaster
Dang that looks like fun!! Last time I took tub off we had a forklift made it real nice!!!
