Another frame swap, then build thread - Page 2 - JeepForum.com
post #16 of 141 Old 11-29-2012, 12:25 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Easy part done. Stripped the frame, Cleaned the garage and moved it inside...
Tomorrow, wire brushing, grinding off uneeded brackets and paint... There isn't alot of work to be done, This frame is super clean
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #17 of 141 Old 12-01-2012, 05:33 AM
responder
For $500 that frame looks really nice! Are you going to do any further stripping to the frame or just paint it up?
responder is offline
post #18 of 141 Old 12-01-2012, 06:46 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I spent a month working on my replacement frame while it was naked. Worked on shock mounts, motor mounts, and took off those rust prone front doubler panels.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #19 of 141 Old 12-01-2012, 07:21 AM Thread Starter
NHfireLJ
NHfireLJ's Avatar
What Don said above... Gonna add some shock mounts etc, and wire brush down the frame, although most if it doesn't need it, before painting the whole thing
ordered the Eastwood internal frame paint as well..
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #20 of 141 Old 12-01-2012, 07:56 AM
JeeperDon
JeeperDon's Avatar
I didn't know there was special internal frame paint. I suspect the kit comes with some sort of hose sprayer to apply it. That could be handy to have later. On mine, I drilled a 1.5" hole on the bottom of both main rails at the very very back, immediately before the rear bumper mount. As a mud defense, I was going to make a small nozzle for some thin hose, park the Jeep on a steep incline, feed the thin hose into the frame from the front and let it wash out the frame to the rear holes. Of course I then moved from upstate NY to Albuquerque, where there is pretty much no mud or moisture.
Web Admin for
post #21 of 141 Old 12-01-2012, 08:04 AM
shippey-ki-yay
shippey-ki-yay is offline
post #22 of 141 Old 12-01-2012, 08:10 AM
responder
Got it! The reason I ask is that my tub is coming off this weekend. Need todo some timeline planning.
Thanks to both of you for the replies.
post #23 of 141 Old 12-01-2012, 02:24 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Don...
http://www.eastwood.com/internal-fra...RCCODE=1SE0761
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #24 of 141 Old 12-01-2012, 02:28 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Got all the crap cut off... Frame wire brushed.... Welded the body mount brackets that sag cause Jeep never welded the tops..... Mounted my MORE extended shock mounts front and rear. (I already had them but never installed) Welded them in place instead of messing with the bolts... Metal prepped the frame and one coat of POR
prep and paint (2).jpg   prep and paint (3).jpg   prep and paint (4).jpg   prep and paint (5).jpg   prep and paint (6).jpg
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #25 of 141 Old 12-02-2012, 07:49 AM
JeeperDon
JeeperDon's Avatar
I'd redo the rear shock mounts. Any flat plate or pocket will will rust where you live. The stock rear shocks mounts have a pocket just waiting to catch dirt and mud, then let it soak up water and rust. I removed those mounts completely for a clean frame there and fabbed a pair with no pocket. It's easy to fab when you have the nice bolt-on shock main bolt.
I also ground off those two side plates in the front. They are just there to reinforce the tie down slots for new Jeep train transport. Lastly, take off the odd little plates from under side of the frame about below the rear shock mounts (two bolts). That small plate used to have a rubber bump stop on it to keep the axle wrap of flat OEM springs from slapping the frame. The rubber long rotted off and now it just holds moisture and rusts the frame.
Web Admin for
post #26 of 141 Old 12-02-2012, 09:05 AM
sdotcarter
Nice friggen work man. Also some good tips from Don.
Very jelious of the garage.
sdotcarter is offline
post #27 of 141 Old 12-02-2012, 10:37 AM Thread Starter
NHfireLJ
NHfireLJ's Avatar
I did drill drain holes for the shock pockets..But I do like the idea of making them cleaner looking... Don, can you post up a pick of your rear shock mount? Thanks
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #28 of 141 Old 12-02-2012, 11:07 AM
JeeperDon
JeeperDon's Avatar
Here you go. It's welded of 3/16 channel and just welded to the top of the frame. The location of the shock mount pin is higher and more forward than the OEM pin. You can look at the Jeep tub on the old frame now to see how much you can move things. This allowed for a longer shock. The back side (outside) that you can't see is just the channel on the frame, which is easy to hose out so nothing will rot anything.
You can see to the left of the new mount the bad spot where the OEM mount had already caused rust to start to dig into the frame.
Web Admin for
post #29 of 141 Old 12-02-2012, 11:37 AM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Thanks!
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #30 of 141 Old 12-04-2012, 12:59 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Redid the shock mounts, Had the MORE brackets that I already welded so I couldnt send em back so...to the cutting wheel and welded up after I removed the factory mounts.
SOLD
YJOTM FEB 2013
NHfireLJ is offline
