Another flat towing thread! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Another flat towing thread!
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15”/16″ Big Brake Kit w/BlaFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 03-31-2011, 08:44 AM   #1
Skulls
1987 YJ Wrangler
Hey all. I've searched around and have not been ablke to find an aswer for my particular question. I have an 87 YJ that has a Ford 8.8 rear, 4L60e trans and NP241 TC. I'm planning on flat towing the rig. I'm OK pulling the drive shafts, but would rather not. As this is not the stock set up, the advice in the owner's manual probably does not apply. What do you all think?
Don't be a baby, just disconnect the drive shafts.
Leave the DS on, put the TC in neutral and Trans in Park.
Leave the DS on, put both the TC and Trans in Neutral.
Illic est non liber prandium
Skulls is offline   Reply With Quote
Unread 03-31-2011, 08:52 AM   #2
captainauti
captainauti's Avatar
Trans in park. T- case in neutral.
Sent from my thundercrap using JeepForum.
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is offline   Reply With Quote
Unread 03-31-2011, 09:00 AM   #3
Flajeeper1
1987 YJ Wrangler
X2. Nuff said.
Flajeeper1 is offline   Reply With Quote
Unread 03-31-2011, 09:11 AM   #4
jbolty
jbolty's Avatar
Like they said. ^^^.
Unless you have an auto locker in the front, like an aussie. If so, you will need to do a little more work.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Unread 03-31-2011, 09:13 AM   #5
timatoe
The 241 works the same as the 231 so same rules apply.
timatoe is offline   Reply With Quote
Unread 03-31-2011, 11:11 AM   #6
Skulls
1987 YJ Wrangler
Great! Thanks everyone. That's the conclusion I'd arrived at, but self doubt began to set in. This is my first Jeep. I've been wheeling Cruisers for years and different rules apply there.
Unread 03-31-2011, 11:18 AM   #7
92 Green YJ
I'm locked front and rear, So i disco both driveshafts just to be on the safe side. Its really not that difficult and only takes me about 5 minutes each end. I only disconnect the shafts from the pinions. I leave them attached to the transfercase and just bungie and or zip tie them up out of the way
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My RigRater Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline   Reply With Quote
Unread 03-31-2011, 01:07 PM   #8
jeep63
jeep63's Avatar
qft.
89 YJ - Locked and Loaded
91 YJ
95 YJ
jeep63 is offline   Reply With Quote
Unread 03-31-2011, 01:44 PM   #9
Lemoore-on
Skulls, now that your original question was answered, I hope you dont mind a short Hi-Jack............
If I put TJ shafts in the 30 to eliminate the vacume disconect How will this effect flat towing? Will I need to disconect the drive shaft?
Lemoore-on is offline   Reply With Quote
Unread 03-31-2011, 01:51 PM   #10
jbolty
jbolty's Avatar
Nope. Only an aussie type locker will cause towing problems
I had a whole thread about this a while back, but here's the potential problem if you have a lunchbox locker. Just FYI
http://www.jeepforum.com/forum/f12/y...7/#post5596452
Unread 03-31-2011, 02:55 PM   #11
Lemoore-on
I remember reading Your thread about the lunchbox type lockers, but didn't remember anything about doing away with the 2 piece axle.
Thanx
Unread 03-31-2011, 03:14 PM   #12
jbolty
jbolty's Avatar
Thanx
That came later. I have TJ shafts now along with the "true neutral" and it tows just fine.
Unread 03-31-2011, 03:16 PM   #13
Lemoore-on
I want to install the "True Neutral" when I do the SYE.
Unread 04-01-2011, 06:51 AM   #14
captainauti
just another thing..... for flat towing, take an hour and pull the steering lock pin so you wont have to use the key to unlock it. my father used the key, but didnt turn the key when he was ready to roll. the wheels were slightly out from straight, and 3 hours in the tire heated up and blew sky high. (well no really that high) it exploded and the belts shreded his fender and marker lights.
SO, PULL THE PIN. imho.
Capt. Nate
aka Scallywag
Unread 04-01-2011, 10:02 PM   #15
Raloma
I pulled the pin on mine. (easy, and one less thing to worry about)
Raloma is offline   Reply With Quote
