Another Electrical issue - JeepForum.com
post #1 of 16 Old 10-05-2013, 03:44 PM Thread Starter
mayhem185
MY 16 YEAR OLD SON'S 95 YJ. I have replaced the bulbs, the flasher relays and cleaned all grounds i could find. heres what i have going on:
when i turn on...
left turn signal: frt and rear works fine
right turn signal: solid in rear, nothing in front
parking lights: fine all around
hazards: driver frt, driver rear, passenger rear - blink, nothing passenger front and only left green arrow on dash blinks
parking lights/hazards: driver frt, driver rear, passenger rear - blink, passenger front - solid, however driver front turn signal and side marker light alternate blinking
THIS IS DRIVING ME CRAZY!!!!!!!
PLEASE HELP !!!!!! HE REALLY WANTS TO GET THIS ON THE STREET.
THANKS!!!!!!!!!!!!
mayhem185 is offline
post #2 of 16 Old 10-05-2013, 05:24 PM
JWELK
Welcome to the Forum:
What about brake lights on left rear? Sounds like the turn signal in the stalk. I had almost identical on my 99 Cherokee. I just operated the switch a couple of dozen times and it cleaned the contacts. I've never pulled the wheel, on a YJ, but there are hundreds of posts on this forum on how to do it, and the tools needed.
Regards,
Jim W
JWELK is offline
post #3 of 16 Old 10-05-2013, 06:23 PM Thread Starter
mayhem185
i didnt even think about brake lights? will check them and get back.
post #4 of 16 Old 10-05-2013, 06:47 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Sounds like the R/F side marker light bulb is out/broken connection.
FWIW, front side marker lights and front turn signals are designed to flash alternatively.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 16 Old 10-05-2013, 06:48 PM
zeus87gn
1987 YJ Wrangler
You have a bad socket in the right front
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #6 of 16 Old 10-05-2013, 06:55 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I think you're right.
I misunderstood the description. I thought the RF worked on hazard.
Max
Mean Max is offline
post #7 of 16 Old 10-05-2013, 07:48 PM
Old4X
1990 CJ7
Last one I chased, a mouse had chewed a wire loom and cut one of the wires going to socket. The simple stuff is sometimes perplexing.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #8 of 16 Old 10-05-2013, 08:04 PM
zeus87gn
1987 YJ Wrangler
Aint it the truth
zeus87gn is offline
post #9 of 16 Old 10-06-2013, 05:37 AM Thread Starter
mayhem185
today we are replacing disintegrating fuel lines and i guess i will order new sockets. this is gonna be a new jeep by the time we are done chasing/fixing!!! we sure are learning alot.
THANKS for the help!!
post #10 of 16 Old 10-06-2013, 06:19 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
http://www.jeepforum.com/forum/f12/h...emoval-981049/
Max
Mean Max is offline
post #11 of 16 Old 10-06-2013, 08:00 AM Thread Starter
mayhem185
Originally Posted by Mean Max View Post
WOW!! That's a little rough!
well we replaced the bad fuel line, took out front right parking light socket to inspect it, pulled the bulb, turned it around and put it back in, VIOLA!!! started working again?! These vehicles are fun to say the least!!!
now on to replacing the sway bar bushings!!
Thanks guys!!
post #12 of 16 Old 10-06-2013, 08:40 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
The bulb being in backwards is common. The required bulb is an 1157 dual element bulb that has 2 alignment pins that have higher/lower locations on the base of the socket to orient the bulb. They can be forced into the socket, and then it will have an issue.
Max
Mean Max is offline
post #13 of 16 Old 10-07-2013, 01:30 PM
zeus87gn
1987 YJ Wrangler
I was close - the same thing happened to me but both my sockets were bad on that front corner
zeus87gn is offline
post #14 of 16 Old 10-07-2013, 04:22 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Not close! You nailed it!
Good on ya!
Max
Mean Max is offline
post #15 of 16 Old 10-07-2013, 04:26 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
Thanks guys!!
Keep this website favorited, trust me lol you will be back!
-April '14- YJoTM- June '15]
The_Goob is offline
