Quantcast Another Body Lift and Spring Lift question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Another Body Lift and Spring Lift question
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 03-09-2009, 07:17 PM   #1
KnightofMopar
Was trying to find the answer searching, but maybe I just suck with that function. I am TRYING to avoid an SYE kit as my jeep is no monster truck, but maybe an off roading event oncein a while/daily driver (SRT 4 is the toy, sorry guys). I am going for the fun factor of having a lifted jeep that I have always wanted: Plans
RC 4" Lift Kit
-2 or 3" body lift
-33" tires (31's came on the jeep when I bought it)
My question is can you do ANY type of body lift after doing the max 4" lift with t-case drop and not have to put in an SYE? Biggest concern is my jeep when i bought it was not in the best shape and the stock body mounts look very very rough and am going to fix these first before my lift kit, but want to make sure I dont screw myself out of the nice suspension lift look . Thanks guys!
KnightofMopar is offline   Reply With Quote
Old 03-09-2009, 07:25 PM   #2
Mean Max
Mean Max's Avatar
Body lifts have no effect on driveline angle or SYE necessity, so you can do it whichever way suits your application best.
MANY folks with 4" lifts will need a SYE, and it's not all that hard or expensive to do. However, should you tempt fate & go without one and have a catastrophic driveline failure it WILL get very expensive. They're cheap insurance, IMO.
Body lifts aren't that bad, or hard to do, even with rusty body bolts. Here's my thread on avoiding trouble when installing a body lift.
http://www.jeepforum.com/forum/f12/body-lift-carnage-how-avoid-693392/
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Old 03-09-2009, 07:42 PM   #3
yjjason
X-Y-J-Con
yjjason's Avatar
I for ran 2.5in. sup.+3"body on my yj no sye. with no problems. but i have installed one now.(sye kit).only because i finally put in my rubi. axles & (for insurance)!!!
yjjason is offline   Reply With Quote
Old 03-09-2009, 08:04 PM   #4
KnightofMopar
http://www.jeepforum.com/forum/showthread.php?t=693392
Max
Maybe there is another way around getting a lift out of the jeep then the 4"? From what I read they are right around a grand and I am not ALL that serious about off roading, just rather enjoy the jeep for the jeep and would like to clear some 33" tires . Just figured the 4" would be the way to go as it was the same price for the 2.5" lift it looked like
Old 03-09-2009, 08:08 PM   #5
geaganj
2006 WK
I'm no expert at any of this, but I've heard from several others that anything more than a 1" lift is too stressful on the mounts. If you're putting a 4" RC lift on, you should be able clear the 33's without a body lift. Again, not an expert, just passing on the little knowledge I have.
Jason
'06 Dark Khaki WK, 3.7 w/QTII, stock
'00 Black XJ, 3" RC lift, Safari Rack (sold...I miss it)
'95 Flat Black YJ, 2.5" RC lift w/1" boomerang shackles, Smittybilt front & rear bumpers
geaganj is offline   Reply With Quote
Old 03-09-2009, 08:34 PM   #6
Mean Max
Mean Max's Avatar
Well, as much as I hate 3" body lifts (or anything over 1") I think for your application (light offroading/trails, mostly going for looks) a 3" body lift & some 5/8" to 1" shackles will help you clear some bigger meats. This would be quite inexpensive and wouldn't strain the driveline. I would recommend using a new set of poly mounts (stock height) and a 3" lift kit.
OMG! I can't believe I just typed that.....
Max
Old 03-09-2009, 08:53 PM   #7
KnightofMopar
Any recommendations on the 3" lift kit? I am assuming i am looking at the same price as the RC 400 plus range?
Old 03-09-2009, 09:05 PM   #8
yjjason
X-Y-J-Con
yjjason's Avatar
i have had no problems with my 3" body lift so far ,i'll see in a few mouths now with new axles!!!???
Old 03-09-2009, 09:22 PM   #9
KnightofMopar
Maybe a 2.5" lift http://cgi.ebay.com/ebaymotors/87-96-Jeep-Wrangler-YJ-2-5-Suspension-Lift-Kit_W0QQitemZ110359367186QQcmdZViewItemQQptZMotors _Car_Truck_Parts_Accessories?hash=item110359367186 &_trksid=p4506.c0.m245&_trkparms=72%3A1171|65%3A12 |39%3A1|240%3A1318
Old 03-09-2009, 09:34 PM   #10
iowajeepers
One thing I didn't see mentioned was a TC drop to help the drive line angle.
I'm running a 4" RC lift with 3/4" shackles and a 1" body lift (as mentioned, doesn't affect drive line angle) with a 1" TC drop. No vibes caused by the lift. Vibes caused by worn bushings, blown TRE's and maladjusted tires but nothing on the driveline to date.
Those days are limited though, I'm going SYE/CV when I do the axle swap.
Cars.
iowajeepers is offline   Reply With Quote
Old 03-09-2009, 09:53 PM   #11
Mean Max
Mean Max's Avatar
New poly body mounts to replace your cracked rubber mounts, $60
http://www.quadratec.com/products/16058_31.htm
And a 3" body lift $105
http://www.quadratec.com/products/16047_303_07.htm
Max
Old 03-10-2009, 12:48 PM   #12
KnightofMopar
Thanks max!
Glock Forum
