another annoying problem - JeepForum.com
post #1 of 8 Old 03-03-2008, 12:07 PM Thread Starter
blacksvt
My jeep has the sputters..... I have noticed lately that when I start up and head out when the engine is cold it "sputters" only when I shift. (i.e clutch in-shift gears-let out clutch-sputters. It only does it on the first 3 or 4 shifts then goes away. Once it did it and the engine stalled.
I just got finished replacing the plugs,wires,cap and rotor hoping that would clear it up. I just had a new serp belt put on by a shop but I really dont think that has anything to do with it, and after the first few shifts everything is fine. I would like to get this fixed asap because it is starting to get nice and I want to drive my jeep and not worry about it breaking down on me. Any ideas?
blacksvt is offline
post #2 of 8 Old 03-03-2008, 12:25 PM
gokusgrill
seafoam with your next oil change?
gokusgrill is offline
post #3 of 8 Old 03-03-2008, 12:52 PM Thread Starter
blacksvt
Ill do that... I get the feeling this is some kind of ignition/sensor problem.
blacksvt is offline
post #4 of 8 Old 03-03-2008, 04:12 PM
SEMO 95 YJ
I had the sputters and replaced my TPS and it fixed the problem. I thought it was gas at first. Do a self diagnostic test and see if your TPS or any other sensor might be going out.
1995 Jeep YJ 2.5L
2006 Hummer H3
1968 Kiaser CJ-5
SEMO 95 YJ is offline
post #5 of 8 Old 03-03-2008, 04:14 PM
pat8942
pat8942's Avatar
This is totally off the subject, but Floyds Knobs, did the guy get a sex change or what?
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #6 of 8 Old 03-03-2008, 05:28 PM Thread Starter
blacksvt
I dont know, it is a goofy name for a town, I dont even realize it until someone says it though. We are all used to it here I guess.
I seafoamed the motor and DAYYYUM... It quieted down quite a but. Starts stronger and idles better too. Ill have to let the motor go cold then go see if it still sputters and stalls. My next attempt is replacing the tps which I have on hand, but would like to take it back if I dont need it...38$ WTF??? All warmed up its running better than ever though!
blacksvt is offline
post #7 of 8 Old 03-04-2008, 12:17 PM Thread Starter
blacksvt
still doing it...I guess I will put the new tps on. Im running out of ideas...anyone?
blacksvt is offline
post #8 of 8 Old 03-04-2008, 02:05 PM
gokusgrill
I'm glad to here that the seafoam took away some of the problem, it works wonders. try the tps and see if it changes.
annoying steering wheel creek...anyone else have this problem. bortz1892 TJ Wrangler Technical Forum 10 08-21-2008 10:13 AM
Minor but annoying electrical problem Cross YJ Wrangler Technical Forum 1 04-06-2008 05:06 PM
Vibes: annoying or real problem? FutureJK TJ Wrangler Technical Forum 5 02-07-2006 05:26 PM
Help with an annoying problem... saint matthew TJ Wrangler Technical Forum 8 07-08-2004 07:32 AM
little annoying brake problem Joe jeep YJ Wrangler Technical Forum 4 05-29-2003 07:34 AM
