Another ammo can console writeup - JeepForum.com
post #1 of 25 Old 03-09-2013, 06:14 PM Thread Starter
'92 vegas YJ
This is one of those random projects. I had an ammo can laying around and decided to make a console out of it.
I really dislike my old console so i took it out. I've been running for a little while with none at all. As much as i like having no console(i really do), I need one for on the trail. I keep some pretty important trail items inside of it, that way its always within reach. With that in mind, this console is built for function rather than looks. Keep that in mind thought the buildup.
I started out with a MK44 mini gun ammo can.
This type of can isn't hinged. The entire lid comes off. I've seen where other people have put hinges on their consoles but it usually looks really ghetto or it just too much work to get it to look nice in my opinion. What I did is just make my can hinge on its own. First I had to cut off the lip on the back portion that stops the lid from hinging up. If you have a can handy you will know what im talking about. After i cut the lip off i just welded the rear handle to the can so it can no longer come off. Just by doing this the can will be able to hinge up no problem.
Heres where i threw a little crappy weld on the back handle
And now it perfectly opens up to 90 degrees
I also wanted some cupholders so I can enjoy a nice cold Dr. Pepper or something on the trail.
I started out with some PVC. Again this is for function not looks. I could care less if it looks ghetto, as long as it holds my drink
Then I measured and cut out some plate for a mounting bracket
It'll sit just like this, the PVC bolted up to the plate
Then the plate welded to the bottom side of the can
after that I threw it in the jeep to see how it fits. It fits great and the height of the can is the PERFECT height to rest your arm on.
Then I installed a locking hasp latch to it.
Finally I painted the cupholders black.
I'll try to get it installed in the jeep tomorrow.
Project was simple and should serve its purpose well.
-Chris
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #2 of 25 Old 03-09-2013, 06:17 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I like the ingenuity of the cupholders. Great writeup. Let us know how it works for you in the coming months.
Luck Favours The Prepared
Anticanman is offline
post #3 of 25 Old 03-09-2013, 06:20 PM
USMCBuckWild
Someone you know is in need of 2 of those mini gun cans.
Looks good Chris! Need to paint it, and add some padding to the top. Once the sun starts beating on it, its gonna get rather warm.... How do you plan to mount it to the tub? Backets or self tappers through the bottom?
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #4 of 25 Old 03-09-2013, 06:24 PM Thread Starter
'92 vegas YJ
Thanks. Will do
Ill see what i can do about getting some more.
I thought about adding some padding to it. Ill probably wait til i get burned really bad then do it. Sometimes you gotta learn things the hard way haha.
as for mounting it, In the front i will probably use some self tapper to the tub. for the rear i have a bracket from my last console. I'll use some bolts to the bracket, and the bracket is then bolted to the floor.
post #5 of 25 Old 03-09-2013, 06:55 PM
USMCBuckWild
Well, after learning the hard way too many times; I can admit I was wrong.
You, Sir, were right about my 8.8 swap. I should have gone with the 4.10s and not the 3.73s.... My trans guy says that is what finished off my 700R4. Not enough gear turning the 38s. At 70 mph the engine was sitting at around 1400 rpm, which put alot of stress on the 3rdgear clutches. Not enough fluid pressure due to the low rpm and the torque of turning the large diameter tires. Built up heat, heated the clutches and caused premature failure. Stepping up to the 4.10s would have helped reduce the stress and prolonged the failure. So, my "frugalness" is costing me 3 times as much now.
post #6 of 25 Old 03-09-2013, 07:44 PM
fuzzy89
Did you put some type of foam or anything in the bottom of your cup holders or what holds cans or cups in them?? its a great idea though i might use it
fuzzy89 is offline
post #7 of 25 Old 03-09-2013, 08:23 PM Thread Starter
'92 vegas YJ
Yea i added some foam towards the bottom. It holds the cans nice and tight in there
Edit: I don't know why my phone attached to image sideways.
post #8 of 25 Old 03-09-2013, 09:23 PM
ben944
I like it, good work. Cup holders look good too, not ghetto at all.
May have to add this to my to do list.
ben944 is offline
post #9 of 25 Old 03-09-2013, 10:00 PM
b_a_mech
Nice job writing this up!
And it looks good and functional
BUILT NOT BOUGHT #602 / ZOMBIE RESPONSE TEAM #40 / USN HULL #196
b_a_mech is offline
post #10 of 25 Old 03-10-2013, 05:08 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
FYI if you go with ABS WDV/pipe caps, they are solid black, no paint needed and even a little cheaper in my area.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #11 of 25 Old 03-10-2013, 09:02 PM Thread Starter
'92 vegas YJ
Thanks guys.
I wish i would've known about the ABS WDV pipe. Oh well, maybe next time
post #12 of 25 Old 03-10-2013, 09:05 PM Thread Starter
'92 vegas YJ
Got the new console installed today.
It's mounted in the aft with 2 bolts, and in the front with a big self tapping screw threw the tub.
bolted to the bracket that came with my old console
post #13 of 25 Old 03-10-2013, 09:10 PM
schitzangiggles
King of Macastan
Lookin good.
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #14 of 25 Old 03-10-2013, 09:20 PM
plym49
You don't need to worry about making a pad for it. In the summer, just throw a towel over it. You do always travel with a towel, don't you?
plym49 is offline
post #15 of 25 Old 03-10-2013, 10:56 PM
Michaelgoesrawr
A man is nothing without his towel.
Michaelgoesrawr is offline
