Another alternator thread - JeepForum.com
post #1 of 5 Old 11-11-2008, 07:19 AM Thread Starter
PolakX
I know, I know this has been beaten to death, but just a quick question .... Lookin to put in a 136a alternator out of 97/98 ZJ, should I be worried about the stock wiring in my YJ not being able to handle the new load?
92 YJ 2.5L 4" Skyjacker, 1" Body Lift, 33" BF M/T,Posi-Lock, Herc'd, ARB Safari Snorkel, Sanden On board Air, Electric Fan
Central NJ Offroading -
PolakX is offline
post #2 of 5 Old 11-11-2008, 07:52 AM
RockWoRM
RockWoRM's Avatar
Should not be an issue. Have a higher amp alt. with zero probs.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #3 of 5 Old 11-11-2008, 10:50 AM
jbolty
jbolty's Avatar
The alternator does not put out any more power than it is asked for.
Meaning, the load is the same until you start adding lights, winch, etc to take advantage of the extra power available. Then you may need bigger wires.
jbolty is offline
post #4 of 5 Old 11-11-2008, 11:09 AM
Brandon_YJ
1987 YJ Wrangler
^Correct!
Stock wiring will be sufficient.
But if your battery cables are not in good condition, it would be a good idea to change/upgrade those at the time.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #5 of 5 Old 11-11-2008, 12:04 PM Thread Starter
PolakX
Thanks guys!
PolakX is offline
Alternator JVona TJ Wrangler Technical Forum 9 01-21-2009 11:15 PM
alternator jeepwcrazy TJ Wrangler Technical Forum 17 01-16-2009 11:09 PM
Alternator HELP please... Tacoma750 TJ Wrangler Technical Forum 5 04-01-2007 09:34 PM
thread from the siping thread....didnt wanna hijack.. 0IIIIII0 TJ Wrangler Technical Forum 3 01-20-2005 11:55 AM
Alternator????? 2000wrangler TJ Wrangler Technical Forum 7 01-13-2005 08:47 AM
