Another 5.2L YJ thread - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Another 5.2L YJ thread
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing our NEW JK tail light adapter wiring harness!!
Unread 04-29-2013, 10:54 PM   #46
Xpress
Not enough Lumens...
Xpress's Avatar
I have a feeling the smog ref will catch those...
My 5.2L Build thread
-1989 Jeep Wrangler 2.5L, soon to be 5.2L
-1996 Jeep Grand Cherokar 5.2L, donor and rainy day driver
-2004 Kawasaki KLR650 sunny day driver
Originally Posted by mudsweatNgearz View Post
Leave em off and weld an I beam on. Bumperetts just scream homo.
"A well regulated Militia, being necessary to the security of a free State, the RIGHT of the people to keep and bear Arms, SHALL NOT BE INFRINGED."
Xpress is offline   Reply With Quote
Unread 04-30-2013, 09:20 PM   #47
Ripper3494
get heat shields and cover em so it looks like they're just stock manifolds. nobody will be the wiser
build thread:
[url]http://www.jeepforum.com/forum/f22/94-yj-6-0-build-spud-1218315/[/url]
1997 ZJ limited - BONE stock
[url]http://www.jeepforum.com/forum/f12/alternator-welder-write-up-1301614/[/url]
[url]http://www.jeepforum.com/forum/f12/tj-uppers-yj-half-doors-hard-top-installation-1417686/[/url]
RC vs BDS
[url]http://www.jeepforum.com/forum/f12/rough-country-vs-bds-1461555/[/url]
Ripper3494 is online now   Reply With Quote
Unread 04-30-2013, 09:20 PM   #48
Ripper3494
dear god my jeep would be sent straight to the crusher in CA
build thread:
RC vs BDS
Unread 04-30-2013, 09:38 PM   #49
SunDevilJeeper
Problem solved.
1992 YJ - 5.2L V8
2003 WJ Limited - 4.7L H.O. V8
Still not enough power.
SunDevilJeeper is offline   Reply With Quote
Unread 04-30-2013, 10:07 PM   #50
Xpress
Xpress's Avatar
Well tonight I started cutting the old motor mounts off. Taking this one step at a time. Will worry about headers down the road..
Unread 05-02-2013, 02:16 PM   #51
Xpress
Xpress's Avatar
Got my Advance Adapters mounts in the mail!!!
Shipped a lot quicker than I expected, have been slowly grinding and cutting away at the old mounts, smoothing them out slowly but surely.
Unread 06-13-2013, 10:48 AM   #52
Xpress
Xpress's Avatar
Just to update this thread a bit, decided it would be more cost effective to keep the ZJ around for awhile until I have enough parts collected to begin really moving forward with the YJ. I still need axles, suspension, transmission, and some other misc parts to get moving forward.
Unread 06-14-2013, 11:02 AM   #53
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
You're officially famous, you made it into the JF newsletter!
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote
Unread 06-15-2013, 09:14 PM   #54
Xpress
Xpress's Avatar
Sweet! Maybe this thread will start to go somewhere
Unread 06-17-2013, 06:13 AM   #55
solomon8718
solomon8718's Avatar
Question for Xpress or really anybody on here who might know. Seems like YJ 5.2 swaps are fairly common over on this forum. I see you are planning on running your ax15 behind the motor? If so from what are you sourcing the computer? As far as I can tell all the manual dodge dakota's with the 5.2 run a nv3500 transmission. Do you know if the pcm is compatible with either the ax15 or the nv3500? I've been digging for the answer to this question all over the interwebs.
Hoping to swap a terminator ax15 behind my 5.9 zj.
97 ZJ GC Limited w/Up Country SOLD - "Muddy Gorilla" build thread
98 ZJ GC 5.9 Limited CURRENT - "Silverback Gorilla" 5.9 manual build thread
- IRO Front Long arm kit, rear adjustable arms
- IRO 4.5" coils
- Bilstein 5125 series shocks
- JKS Quick disconnects
- 249 -> 242 swap
- Kolak 3" exhaust w/flowmaster 70
Selling my long arms
Originally Posted by myjeeplovesmud View Post
with that said, for those i may have frustrated when i was noob, i'm sorry, but thanks for not driving to my house with a bat.
solomon8718 is offline   Reply With Quote
Unread 06-17-2013, 09:06 AM   #56
Xpress
Xpress's Avatar
That is a bridge I will attempt to cross when I get there. As far as I am concerned, a transmission is a transmission.
Unread 06-17-2013, 12:36 PM   #57
warthog312
The Craigslist Crawler
warthog312's Avatar
so what CAN you do in Cali???? It seems like they poo-poo everything that attempts to make a vehicle perform better than stock. I mean, headers? REALLY??? I live in Chicago, third largest metro in the US, and they don't care one iota what you do to your vehicle pre-OBDII. Every vehicle I've ever purchased: step 1 - cut off cats.
I've got buddies with carb'd OBDII cars that have 'dummy ECMs" that throw an 'everything is just fine under here, no reason to pop the hood' signal for when they go to emissions testing, which is just a quick OBD scan every few years. One in particular is an F-body T.A. with a 383 and four barrel which has a cam so large the car will barely idle, and when he went for testing the guy just had kind of a puzzled look as the scanner said everytihng is fine....
Click for build thread: HONEYBADGER - 302//435//20//8.8
>>>the single greatest investment you can make for your jeep is to buy a good welder, and learn how to use it<<<
warthog312 is offline   Reply With Quote
Unread 06-17-2013, 01:58 PM   #58
bmgadg
Mopar 5.9 + AX-15 + mid 90's dakota bellhousing + mid 90's OBD1 computer from a 5.9 dodge ram with manual trans.
That's what I'm running.
92 YJ Trail Project
06 XK Commander Daily Driver
My YJ Build Thread Magnum 5.9L 360, full width SOA
bmgadg is offline   Reply With Quote
Unread 06-17-2013, 02:40 PM   #59
solomon8718
Thanks for the info, though I'm not sure how helpful that is for me. My 5.9 is odbII.
- IRO 4.5" coils
- 249 -> 242 swap
Unread 06-18-2013, 09:34 AM   #60
bmgadg
Mine was too originally. I converted it to OBD1.
92 YJ Trail Project
