Another 5.2L YJ thread - Page 14 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Another 5.2L YJ thread
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBds fox ipf 2.0 racing series shocks now available at rockFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 11-07-2013, 04:57 PM   #196
SunDevilJeeper
Originally Posted by Xpress View Post
Here we can only use an engine that is the same model year or newer. It sucks, but I guess that's what we get for letting Democrats control the state..
Enough politics though, I am going to start searching for that ellusive bellhousing...
Which headers did everyone say will work with the 3.9L bellhousing?
Patriot/Summit tight tuck headers (not recommended) or the Hedman block huggers.
car-part.com is your friend when looking for stuff like this in case you didn't already know about it.
1992 YJ - 5.2L V8
2003 WJ Limited - 4.7L H.O. V8
Still not enough power.
SunDevilJeeper is offline   Reply With Quote
Unread 11-07-2013, 07:29 PM   #197
Xpress
Not enough Lumens...
Xpress's Avatar
Another question I have is what to do about gearing?
35" tires will be the rubber of choice, so what to go with...
My initial research and edumacated guessing tell me that I should go with 4.10's. I don't want to over-rev the V8 on the highway, I'd like to keep it around 2100rpms in 5th at 65 mph. Don't care if I have to downshift for long steep highway grades.
My 5.2L Build thread
-1989 Jeep Wrangler 2.5L, soon to be 5.2L
-1996 Jeep Grand Cherokar 5.2L, donor and rainy day driver
-2004 Kawasaki KLR650 sunny day driver
Originally Posted by mudsweatNgearz View Post
Leave em off and weld an I beam on. Bumperetts just scream homo.
"A well regulated Militia, being necessary to the security of a free State, the RIGHT of the people to keep and bear Arms, SHALL NOT BE INFRINGED."
Xpress is offline   Reply With Quote
Unread 11-07-2013, 08:32 PM   #198
skyj
Im going to be running 4.56 with my 35's mainly because that is what I have currently in my axles. I do plan to jump up to 37" as soon as the 35's wear out. I think 4.10 will be fine with the 5.2. If I remember correctly moparfreak runs 4.56 with his and 35's too.
My buddy runs a sbc 350 with a sm465 and 4.10 with 37's and he has more than enough power to cruise. I know there is some sort of a calculator to figure out your final drive ratio.
build thread: http://www.jeepforum.com/forum/f22/skyj-eccentric-build-1467426/ '90 YJ 5.2 magnum MPI, AX15, NP231 SYE, Dana 30 4.56 open/ 8.8 4.56 detriot locker. 1" shackles
skyj is offline   Reply With Quote
Unread 11-07-2013, 10:27 PM   #199
SunDevilJeeper
The 5.2 Magnum and LA 318 aren't Ford engines. The mighty 318 is the Mopar engine that gained a massive reputation for being a stout *** little engine. Those things are legendary for taking a serious beating and keepin on afterward. The cash for clunkers program proved that legend when a lot of people had to try ther damnest to kill those 5.2s.
So with that being said, 4.10 will be fine. A little under geared, but it'll do. You'll wanna go steeper than that though.
4.56 if you do a lot of highway driving and care about MPGs, 4.88 if you prefer more power, and a better crawl ratio, but don't care about highway RPMs and fuel mileage.
Either way, you'll be around 2700-3000 RPM with 4.88s and 35s at 75mph
1992 YJ - 5.2L V8
Unread 11-08-2013, 06:48 PM   #200
Xpress
Xpress's Avatar
Like I said I'd like to stay closer to 2000 rpms for that factory feeling. I'm anal about RPM's.
If 4.10's and 35's is too tall then I could always drop a tire size or 2 on the road, then keep the 35's for offroad shens.
Unread 11-09-2013, 03:52 AM   #201
mike_breaker_5
mike_breaker_5's Avatar
if you want to retain a factory feeling you may want to be slightly over 2000rpm's. remember that with larger tires comes more rolling resistance and added weight to the axle. the 5.2 starts to wake up around 2200-2300 rpms, keeping the revs lower than 2000 will cause your motor to always be straining at highway speeds. when i was running 31x10.5x15's on my stock gearing with the 5.2 i was only at about 1700rpms at 60mph, needless to say i rarely got to use 5th gear.
Ratmonkey donation page. all proceeds will go to his family.
http://www.youcaring.com/memorial-fu..._source=widget
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
http://www.jeepforum.com/forum/f22/m...r-junk-990191/
mike_breaker_5 is offline   Reply With Quote
Unread 11-09-2013, 07:58 AM   #202
Xpress
Xpress's Avatar
I don't mind running 2200-2300 rpm's, it's just that I don't want to be over-revving it at 2800+. Obviously it's not going to be a trailer queen
I'd like to retain some decent fuel economy whenever I do decide to accomplish some urban krawling....
Unread 11-11-2013, 09:59 AM   #203
Xpress
Xpress's Avatar
Bump.
Looks as though KC has decided that they want their lights on my rig. They just introduced a few new lines of LED lights and expanded their other lines. Still waiting to see if they introduce a 5x7 LED headlight- they already introduced a 4x6 LED headlamp that will work perfectly on my motorcycle. And they aren't outrageously priced either, rather reasonable, comparable to the other manufacturers, with even more light output...
And anybody that knows me knows that I'm bat**** crazy when it comes to light... There is not enough light out there to satisfy my needs... Hell my bike has 4 ****ing LED lights on it and that's still not enough!!
Unread 11-11-2013, 12:17 PM   #204
SunDevilJeeper
The entire ****ing world is contained within the internet... and not a single ****ing picture or video of the LZRs in action is anywhere out there on the net. Just people taking a picture of the light itself, or diagrams showing what it supposedly does.
Makes me wonder if the KC LZR isn't worth a damn, it's been out for quite a while. There should be loads of info on them by now.
1992 YJ - 5.2L V8
Unread 11-11-2013, 09:03 PM   #205
Xpress
Xpress's Avatar
I think it's because when people think of KC, they think of Halogen round spot lights. And to be fair I haven't seen much advertising for them, aside from the occasional Facebook post, not as of late. Not much in offroad magazines or around the forums either.
Either way, I want to stick with KC. They have done me good in the past, no reason just to abandon them with new product lines coming out.
Unread 11-18-2013, 06:07 AM   #206
Chris
Guy with jeep
Chris's Avatar
Just wanted to add that I drove my 5.9 yj yesterday and it was a blast.
Chris is offline   Reply With Quote
Unread 11-18-2013, 07:36 AM   #207
SunDevilJeeper
Their initial price tag might be why nobody has really bought them. I remember looking at them in the qtec catalog and saying "**** that" a while back.
I just wish there were some actual videos or pictures of their brightness.
Literally.
1992 YJ - 5.2L V8
Unread 11-18-2013, 10:36 AM   #208
Xpress
Xpress's Avatar
^Their pricing is right on par with some of the other manufacturers high end lights.
As far as the 3.9L bellhousing goes, does it have to be a specific year or drivetrain (I.E. 4x4 or 4x2)?
Unread 11-18-2013, 11:16 AM   #209
skyj
Mine is from a '94 2 wheel drive with the 3.9L. I think it has to be a 2 wheel drive but not positive about that.
Unread 11-19-2013, 09:21 AM   #210
Xpress
Xpress's Avatar
Anybody else?
I got a quote from Quality auto Parts for $325 shipped from a 1995 3.9L 4x2. Not quite sure I want to spend that much on a bellhousing...
