Another 5.2L YJ thread - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Another 5.2L YJ thread
Swag Off Road BIG-HIT TJ-YJ Rear BumperThe RuffStuff "I can't go to EJS" Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-03-2013, 07:45 PM   #151
Chris
Guy with jeep
Chris's Avatar
I will donate a wrench and a swift kick in the ***!
Chris is online now   Reply With Quote
Unread 08-03-2013, 09:55 PM   #152
Xpress
Not enough Lumens...
Xpress's Avatar
Sweet a free wench! Anyone else?
My 5.2L Build thread
-1989 Jeep Wrangler 2.5L, soon to be 5.2L
-1996 Jeep Grand Cherokar 5.2L, donor and rainy day driver
-2004 Kawasaki KLR650 sunny day driver
Originally Posted by mudsweatNgearz View Post
Leave em off and weld an I beam on. Bumperetts just scream homo.
"A well regulated Militia, being necessary to the security of a free State, the RIGHT of the people to keep and bear Arms, SHALL NOT BE INFRINGED."
Xpress is offline   Reply With Quote
Unread 08-03-2013, 11:06 PM   #153
19Mike95
You help put a 4bt in mine ill help with yours rofl
19Mike95 is offline   Reply With Quote
Unread 08-04-2013, 12:12 AM   #154
caoboy
Originally Posted by mike_breaker_5 View Post
you can run an auto ecm on a manual and vice versa.
obd1 ... if you put an auto ecm on your manual all that happens is the air fuel mixture is a little diff to compensate for having a torque converter.
i ran an auto ecm with no problem for a while on my 5.2 before switching to the 5.9l manual ecm on my 5.2. hell... i even ran an auto 3.9l ecm on my 5.2 for about 1/4 mile. guy i bought it from said it was for a 5.9 not a 3.9. i quickly notified him of his mistake.
obd2...
not 100% positive but i think it is a possibility to put an auto ecm on a manual if you do something to trick the computer to think the transmission is always in drive. otherwise the ecm thinks your in park all the time and you have a terrible power loss. i know i read this somewhere on someone's swap thread but i can't remember for the life of me who it was or how he "tricked" the ecm.
The issue with California C.A.R.B is that the ECU has to be the same as the transmission. You can't jerry rig anything, all emissions equipment has to be there and working, as it as from factory, from the original vehicle.
caoboy is offline   Reply With Quote
Unread 08-04-2013, 03:55 AM   #155
mike_breaker_5
mike_breaker_5's Avatar
i wanna know how they are going to tell that it's an auto or manual ecm?most inspection places around here(PA) barely know how to operate a pen, nuch less tell if all pieces of a vehicle are stock.
besides... i wasn't talking about the 50 state legality of it, that's for whoever to figure out, i was speaking from the physical possibility of the matter.
Ratmonkey donation page. all proceeds will go to his family.
http://www.youcaring.com/memorial-fu..._source=widget
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
http://www.jeepforum.com/forum/f22/m...r-junk-990191/
mike_breaker_5 is offline   Reply With Quote
Unread 08-04-2013, 08:22 AM   #156
caoboy
They hook into the obd2 port and also physically check it. They comb the motor. They want you to pass, so even if you do fail, they show you what you need to do to fix it.
Unread 08-05-2013, 11:05 PM   #157
Xpress
Xpress's Avatar
Well that is reassuring, though I think I can do it right the first time. Do they charge to do a re-test?
Unread 08-06-2013, 06:11 AM   #158
caoboy
Call your local CARB ref and ask, its been a while since I've used them, and idk if it is different for a truck. Chat them up, let them know what you want to do. Theyll give you info you need to know.
Unread 08-06-2013, 06:19 AM   #159
mike_breaker_5
step one, move out of communist California.
step two, start your motor swap.
Unread 08-06-2013, 07:39 AM   #160
remmons
Senior moments member.
2002 KJ Liberty
I Have nothing against California, other than the strictness of their emissions regulations, but I can see why they have them.
2002 Liberty Sport 3.7. 2.5" lift. Mostly all stock.
remmons is offline   Reply With Quote
Unread 08-06-2013, 07:49 AM   #161
Chris
Guy with jeep
Chris's Avatar
There is no reason for failing people over a visual inspection. If you motor is putting out the correct numbers it should matter how you have it set up.
Unread 08-06-2013, 11:21 AM   #162
Xpress
Xpress's Avatar
No. I will start it when I damn well please
Unread 08-06-2013, 12:26 PM   #163
remmons
2002 KJ Liberty
Unread 08-06-2013, 01:18 PM   #164
DLWRUBI
Couldn't agree more. The only thing they should care about smog wise, is the emissions coming out the tailpipe.
DLWRUBI is offline   Reply With Quote
Unread 08-06-2013, 02:17 PM   #165
remmons
2002 KJ Liberty
They do sometimes check for smog equipment to see if it is intact, i.e. a Catylitic Converter. But, they wouldn't know what to check for in an A.I.R. Injection system due to the many types that are installed on the many brands of vehicles, or if the PCM (ECM) is the proper unit for the vehicle.
