Another 4.0 Swap question...head swap vs. full engine swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Another 4.0 Swap question...head swap vs. full engine swap
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!DIY tube fender kitsAmsteel Blue Synthetic Winch line Free Shipping
Unread 07-27-2009, 03:31 PM   #1
Mol
Disclaimer: I'm Polish
Mol's Avatar
I just got a text message from one of my friends. He is swapping a small block for his 4.0 HO, and he wants to sell his 4.0 and ax-15. I'm still waiting to hear what he wants to sell everything for, which may be a determining factor.
What are your opinions on a head swap with howell kit vs. head swap with weber vs. swapping for the full motor.
He has had issues with his yj, and he seems to think that it is either a bad sensor in the tranny or a sensor in the wiring harness? If its a bad tranny, that's fine, mine is great. He is not a close friend, so I really don't know what his exact issues have been, just that it intermittently bogs down real bad and is almost completely devoid of power.
Swap for the motor or continue to build my 258?
2008 JKUR
Raceline - Maxxis - Currie - Synergy - Offroad Evolution - Reid Racing - RCV - Pretty ****ty Crap (PSC) - River Raider - Warn - MBRP - KC - AEV - Offroad Heros - BFG - Teraflex - BDS - Fox - Eibach - Moog
2012 JKU
- The smoking hot wife mod -
Mol is offline   Reply With Quote
Unread 07-27-2009, 06:05 PM   #2
warhog-06
If it were mine I would do the head swap w/ weber carb (which is actually what I am getting ready to do). Sounds like there is some trouble somewhere, by just using head you eliminate all electronic issues, etc. Changing the head, adding weber carb, and removing emissions (if possible), should gain you 40 - 50hp. Just spend a few hundred bucks and have the head decked (if needed), valves ground, etc., before installing. Nothing worse than going through the trouble to change head and then find out it is warped or the valves leak.
warhog-06 is offline   Reply With Quote
Unread 07-27-2009, 06:12 PM   #3
Mol
Mol's Avatar
Yeah I have already bypassed emissions. Thanks for the input, you have affirmed my thoughts exactly with the potential troubles with his setup. What should I offer him for the head? I see people asking between $120-$200...but we all now what people ask and what they net are two entirely different things
2008 JKUR
2012 JKU
Unread 07-27-2009, 06:19 PM   #4
warhog-06
Hard to say. Some people would want to charge you more to take the head off (more work for them). Most wouldn't want to remove because they want to sell the engine as a whole. However, try getting it cheap (since you know there are issues), and you have to have it machined. Maybe he will bite (pull it your self?).
Unread 07-27-2009, 06:26 PM   #5
Mol
Mol's Avatar
yeah pretty good chance I can get it for a good deal...he has a mutual friend do his work, and I am the only other jeeper he knows. He wouldnt have anyone to sell it to otherwise. I'll give it a shot at $50 and see what he says
2008 JKUR
2012 JKU
Unread 07-27-2009, 06:34 PM   #6
warhog-06
Now your talking. If you get it for $50, I'll buy it from you for $60. LOL
Unread 07-27-2009, 07:37 PM   #7
Mol
Mol's Avatar
Think I'm safe using the exhaust manifold and intake manifold from his motor? Or do I look at buying new?
2008 JKUR
2012 JKU
Unread 07-28-2009, 03:06 PM   #8
warhog-06
I would go ahead with his. There isn't much to go wrong with them, just clean and check everything over good. Definitly new gaskets. Good luck.
Unread 02-26-2010, 04:41 PM   #9
green89yj
So you have to get a new 4.2 head gasket and JB weld in the extra water jackets. Which pushrods and stuff do you use?
Build
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline   Reply With Quote
Unread 10-17-2010, 05:36 PM   #10
lclark2074
lclark2074's Avatar
to keep the carb you will need the intake from the 4.2 and the ext from the 4.0
night crew 226
http://www.jeepforum.com/forum/f12/f...l-box-1471348/
lclark2074 is offline   Reply With Quote
Unread 10-17-2010, 06:27 PM   #11
ThisGuyUKnow
1982 CJ7
If you are getting the whole drive train and want to keep the 258with the 4.0 head why not use all the fuel injection components? That way you get the benefits of MPFI over a carb.....
You will also have the parts between the 2 motors to make a 4.6 stroker which is basically a 4.0 with the rods and crank (if you want it to run off 87 octane you need to have the head worked on to change the compression a bit) it could be run with the stock 4.0 computer or a carb since the 4.2 intake will bolt to a 4.0.
1988 Grand Wagoneer360/727/229 Dual Contour fan, Ebay HEI(Should of Done the Team Rush), Cherokee W/T Axles 3.31
1982 CJ7258 Block, 4.0 Head/MPFI, 91 Xj Serpentine, Ax15, Twin Sticked D300,2.73 stock gears.
2004 Honda 919Naked Sport the way I like it!
ThisGuyUKnow is offline   Reply With Quote
Unread 10-18-2010, 04:11 AM   #12
wendell
1987 YJ Wrangler
On my 4.2, I swapped on a 4.0 HO head, comp cam, rollor rockers, offy intake, holley 470 TA 4 barrel carb, header, DUI and MSD. It romps and there's no sensors or computer to worry about. EFI is great, but it's not the only solution for the 258. The holley TA series 4 barrels are made for off road and will take some extreme angles and there dependable as well as easy to work on. I'm very happy with the power and simplicity of a carbed 258. It makes more power than a 4.0 at a little lower rpm to boot.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline   Reply With Quote
