Amp Install - '90 Wrangler - JeepForum.com
post #1 of 3 Old 04-25-2001, 11:21 AM Thread Starter
InspGadgt
He3y Folx,
Newbie here. FINALLY got ahold of a '90 Wranlger (4 cyl, but got one)(soft top, no rear seat)
I want to install an audio amp but not sure the best location. I usually wheel with bikini top on, so have to keep that in mind.
Also......stock body height, what size wheels ca I get away with throwin' on it without having to lift?
Thanx
-= IG =-
InspGadgt is offline
post #2 of 3 Old 04-25-2001, 11:37 AM
Tonka
2015 JK Wrangler
I can't help you with the amp location(mines bolted under the back seat), but the largest tire without rubbing is a 30x 9.50 r 15 on stock rims(or at least stock backspacing)
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #3 of 3 Old 04-26-2001, 06:36 AM
LNDSRK
I recently had my stereo system taken out of mine. My amp was installed under the front seat, driver side. My solution was buying the Insta-Trunk through JC Whitney for $100.00. My new amp was installed yesterday, and unless a thief has the time and patience, he isn't going to be getting the amp out. Also put two 6x9 inside Tuffy's Speaker & Security Lockbox. These bolt to the wheel wells, and are made from 16 gauge steel.
1995 YJ - Some mods...with more to come (Just Emptied Every Pocket)
LNDSRK is offline
RB1 Install in 2001 Wrangler Guermont TJ Wrangler Technical Forum 3 07-09-2009 02:52 PM
Cost of complete AC install on 02 wrangler x chaznad TJ Wrangler Technical Forum 3 02-24-2009 04:09 PM
95 wrangler hitch install supermopar YJ Wrangler Technical Forum 8 01-01-2009 05:07 PM
any1 install a RB1/RB4 on a 2001 wrangler? CorvetteZ06 TJ Wrangler Technical Forum 1 02-16-2007 11:29 PM
How to install dash speakers in 95 Wrangler? SublimeHiPpOs YJ Wrangler Technical Forum 18 04-04-2005 11:00 AM
