??? amount of lift/type with 35" tires. Planning for the future. - JeepForum.com
post #1 of 5 Old 01-03-2010, 08:30 AM Thread Starter
rigger
Just picked up a little 95 Wrangler that has really good potential. Right now it is all stock and has a body that is not perfect at all. So now I am planning for future mods for it.
What I am trying to gather is info on different mods and what went along with them.
I have a buddy that is wanting to upgrade his Wrangler so I am looking at getting his 35" BFG's and wheels. And maybe his axles in the future too.
We are thinking of doing a spring over swap and his 35's. I would really like to keep the C.of G. low so maybe tubing the front fenders if it is to tight. This seems to be the most cost effective way to lift it. I know there may be some other ways to lift or maybe better ways to lift.
What are some pro's and cons's of different lifts or any other major issues that may need to be addressed at the same time?
And this is also a daily driver for me too so keep that in mind. What ever I start needs to be completed by Monday morning so I can go to work.
And the end project needs to look sharp too. I might be driving a rusty rig at the moment but I want to end product to look good when it is all said and done.
rigger is offline
post #2 of 5 Old 01-03-2010, 08:53 AM
martysmilt
Daily driver?
My experience with modifying a daily driver has been both frustrating and ego satisfying. I really enjoyed the look on peoples faces when I rolled into the lot at work with my old YJ. The problem with wheeling a daily driver and modifying same is obvious in hind sight. You rely on a daily driver to get you to work to earn money to play and live. If you have a major problem with the daily driver you have the real potential to loose the ability to support yourself. I solved the problem with a second car - - "The beater" as my daily driver did not have to get modified on a time table. It was not pretty but was reliable. I used it when the beast would not cooperate with my work schedule. It was the BEST upgrade I did to my 1st YJ because it gave me the ability to fix the beast with the correct parts with no compromises. I got to work on the beast on my schedule. It protected my income source my lifestyle and my family. I know that it is not a cool upgrade that satisfies your ego with instant gratification. It will allow you to build a really cool Jeep over time.
Now that I have said that I need a favor, Please measure and post the distance from the top of the axle tube to the frame on your Jeep. I am starting a new thread on the subject.
Thanks,
Marty S
martysmilt is offline
post #3 of 5 Old 01-03-2010, 10:37 AM Thread Starter
rigger
From frame to axle on the front is 6" and on the rear it is 6.5". That is to the frame, not to the bump stops.
I was originally going to go no bigger than 33's on it and that may still be the way that I go. But, I know by the time I buy new 33's, rims, lift and so on, I will have more money invested than if I get my buddies 35's and his rims. His tires are in great shape and have at least 75% of life left in them.
He also has a nice axle, re-built, locker, bigger gears and disk brakes that I will probably get from him too. I know it will make a nice up-grade to mine.
We were thinking of doing a spring over lift and his 35's on mine. Then if needed tube the front fenders. But I am not sure if that alone will be enough lift for it. Then a little later down the road, after he gets new axles for his, swap his old axle onto mine.
Just looking for thoughts and things that you guys have run into so that I can plan ahead and have as little down time as possible.
I do have co-workers that drive right by my house everyday so if a weekend project took longer than I thought it would, (and I am sure it will), I can still catch a ride to work.
rigger is offline
post #4 of 5 Old 01-03-2010, 01:32 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Take a look in the FAQ sticky thread & read-up on SOA & what some of us have done to address things. This should give you a baseline as to what you will be getting into.
Just remember - for each "shortcut" or method/approach taken to save $ or use of parts that are not ideal, there will be a price to pay in performance.
I have seen several SOA projects where I would never even think of taking those rigs where you would think they should be capable of going knowing they were built poorly and too many shortcuts were taken. So what I'm saying is...take your time, do your research, and don't be in a hurry or else a can of worms will be the result.
Joe Dillard is offline
post #5 of 5 Old 01-03-2010, 03:06 PM Thread Starter
rigger
I will check that out. Thanks.
I don't mean to sound like I want to cut corners. That is not the plan at all. I do what to do it in a good and safe manner but at the same time, get the biggest bang for the buck.
Plans and problems are why I am looking into and asking questions now.
I was under the impression that a spring over was a good way to lift given that it was done properly. Please do correct me if I am wrong. If it is a problem child way of lifting, then I will stay away from doing it like that.
I don't have to use my buddies 35's. I was just trying to think of a good way to use them.
Would it be better and safer to run something like a 2" heavy duty shackle lift and maybe a 1" body lift. Then maybe run 33"s on it? I would kind of like to keep the stock springs to retain the ride it has now. I really do not want it to get any stiffer.
Please do give me your opinions guys.
rigger is offline
Future Planning: Flat T-Case Skid Panici TJ Wrangler Technical Forum 4 05-03-2012 08:37 AM
Future planning = Tom woods SYE + Flat skid + lift? Panici TJ Wrangler Technical Forum 2 03-18-2008 12:01 AM
Planning some upgrades for the future... did I miss anything? mahgnillig TJ Wrangler Technical Forum 5 05-09-2007 10:57 AM
Planning my future SYE. I think this is what I need kaybone TJ Wrangler Technical Forum 4 12-30-2006 02:42 PM
planning on doing an SOA in the future. Jakesteads YJ Wrangler Technical Forum 1 08-29-2006 07:52 PM
