Amc 401 yj - JeepForum.com
post #1 of 33 Old 05-22-2013, 10:22 AM Thread Starter
mousemjh12
In the process of doing an engine swap in an 90' YJ. I'm running 44" Super Swampers with 4.56 gears as of right now. I had an inline 6 but have purchased an AMC 401 to put in its place. I currently have the AX15 transmission and NP 231 transfer case but have the plan of replacing with a T19 transmission and Dana20 transfer case. What are all of the issues that I will run into and how do I go about fixing them?
mousemjh12 is offline
post #2 of 33 Old 05-22-2013, 10:29 AM
Randonexplosion
Randonexplosion's Avatar
The first thing that I can think of is your Dana 20 t case will be passenger side drop.
Randonexplosion is offline
post #3 of 33 Old 05-22-2013, 10:40 AM Thread Starter
mousemjh12
Yep, discussed that last night. Is there an easy fix? Do they make an adaptor? Or would it be unwise to cross it over?
post #4 of 33 Old 05-22-2013, 10:42 AM Thread Starter
mousemjh12
Forgot to mention that I'm running a Dana 44 up front and a Dana 60 in the rear.
post #5 of 33 Old 05-22-2013, 10:47 AM
Randonexplosion
I dont know much about flipping transfer cases but I know it can be done. Check out Novak or Advance Adapters for the drivetrain adapters
post #6 of 33 Old 05-22-2013, 12:55 PM
instg8tor
wouldn't it be easier to get a chevy 44 or 60 front and not worry about flipping the xcase?
'91 Renegade - Waggy 44/20 (F/R Aussie) SOA, E350 MC, York OBA, Custom F/R bumpers
instg8tor is offline
post #7 of 33 Old 05-22-2013, 01:01 PM
Randonexplosion
I would think so. Or try to adapt the trans to a 241 to keep it driver drop.
post #8 of 33 Old 05-23-2013, 05:42 AM Thread Starter
mousemjh12
That was another option. I found a Chevy Dana front 44 with Ford lockouts and a Chevy 14 bolt rear end with matching 4.10 gears, so that might be might best bet I'm guessing at this point
post #9 of 33 Old 05-23-2013, 12:41 PM Thread Starter
mousemjh12
If I were to go with Chevy axels, what gear ratio would be best suited for my set up?
post #10 of 33 Old 05-23-2013, 03:09 PM
YJ4LIFE
why not run the ax-15?
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #11 of 33 Old 05-23-2013, 03:35 PM Thread Starter
mousemjh12
I could, I'm not against it, just came across the T19 and Dana 20 for dirt cheap and they were in great condition, I'm still learning but I've had a few people tell me that the AX15 is hard to beat, just not heavy duty
post #12 of 33 Old 05-23-2013, 05:54 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
not the best motor in the world, it can be built, but it's expensive to make any decent power from. a fuel injected 4.0 makes similar numbers stock vs stock.
for 44's i'd be looking for minimum 5.38 gearing, probably even higher with bigger axles. i really can't believe you're able to go anywhere that isn't pavement with 44's on a d44/60 combo too. that's a lot of tire.
ratmonkey is offline
post #13 of 33 Old 05-23-2013, 07:00 PM
Chrisnvegas
Chrisnvegas's Avatar
44" super swampers. For mud? If so, a built automatic. Period.
"Auto racing began 5 minutes after the second car was built."
Henry Ford
Chrisnvegas is online now
post #14 of 33 Old 05-23-2013, 07:22 PM
mike_breaker_5
there is nothing about an ax-15 np231 combo in front of 44"s that is going to last very long. especially after tossing in v-8 power. the ax-15 will give up the ghost first, i speak from experience.
44"s is alot of tire like rat said, there is no way on gods earth i would think anything numerically lower than 5:13's would even come close to keeping you in the power band for the older 401 amc motor.
i am merely going on speculation since i have no concrete evidence other than common sense to go on. it is pretty much a standard to go with 4:88's on 37"s, this is the only piece of data that i am basing my statement on.
i'm not even going to touch the axle debate, god kills a kitten every time someone argues axle/tire pairing on JF.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #15 of 33 Old 05-24-2013, 12:04 PM
remmons
If your front D44 is a right hand drop, then you should have no problems with that set up. I would have to agree that the stock 401 v8 vs. injected 4.0 both produce nearly the same numbers, and both can make great motors if you're willing to invest in them.
But, my old hot-rod motto is "there's no replacement for displacement."
Robert.
remmons is offline
