am trying to replace head light dimmer switch - JeepForum.com
post #1 of 2 Old 06-08-2009, 09:37 AM Thread Starter
Kil_roy
Hey yall , just got a 93/95 yj wrangler, with high beam head lights only, im trying to change the dimmer switch, i need a sterring columm brakedown an what tools to use, is this a job i can do, or take it to a mach?
thanks much.
Kil_roy is offline
post #2 of 2 Old 06-08-2009, 09:41 AM
jdarg
What are the symptoms - are the high beams actually on or is the dash indicator on but the high beams aren't? The later usually indicates a wiring issue which may be as simple as the connector not plugged near the steering column.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
Help! How do I replace the brake light switch? wranglerxls TJ Wrangler Technical Forum 25 08-27-2016 08:11 PM
Having problems with lights. Does the dimmer switch run through the headlight switch? spshultz YJ Wrangler Technical Forum 2 10-25-2009 06:43 AM
Can I Replace Headlight Dimmer Switch w/Toggle? ChibbMD YJ Wrangler Technical Forum 9 07-17-2009 09:59 AM
dome light won't come on with switch, dimmer not working either mike06X TJ Wrangler Technical Forum 2 11-14-2005 09:33 PM
head light switch safarimike TJ Wrangler Technical Forum 1 11-13-2005 05:40 PM
