Am i doin something wrong - JeepForum.com
post #1 of 20 Old 04-10-2010, 02:25 PM Thread Starter
Tcarsten
I have everything done on my 8.8, breaks are not working.
I bleed them and the fluid has no air in it.
still no breaks
what am i doin wrong???
I have the WJ breaks in the front are they pulling all the pressure away from them??
Im lost
Tcarsten is offline
post #2 of 20 Old 04-10-2010, 02:26 PM
provinT13
Not sure about the WJ brakes, but did you make sure the left was on the left and the right was on the right and that they're not upside down? Do you have any leaks anywhere?
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #3 of 20 Old 04-10-2010, 02:30 PM Thread Starter
Tcarsten
never thought to see if they were on the right side hahaha
Ill check right now
no leaks
Tcarsten is offline
post #4 of 20 Old 04-10-2010, 02:35 PM
provinT13
Well what I was referring to was my banjo being upside down, it was causing mine to leek, but I was mistaken about what had actually happened.
I think you're problem is they're still not bled enough. Make sure you're really bleeding the brakes, and I mean really really bleeding the brakes. The first time I bled them I thought it was all good. I didn't think there was any air in there but it turned out there was. You really have to slam the pedal down, and pump the brakes before you open the bleeder valve.
Btw- If you're in Colorado Springs I can come help
post #5 of 20 Old 04-10-2010, 02:40 PM Thread Starter
Tcarsten
k ill just keep bleeding them i guess
yea im in pueblo but hey its only 45 min. away lol
Thanks though
Tcarsten is offline
post #6 of 20 Old 04-10-2010, 03:48 PM Thread Starter
Tcarsten
Ok so it builds up pressure when I pump it alot
but when i let off the pedel it goes to the floor after a second.
Is my master done?? it makes a noise when you let off the pedel?
Tcarsten is offline
post #7 of 20 Old 04-10-2010, 04:01 PM
provinT13
Yes you want it to go straight to the floor. Are you doing it with 2 people? I had to have my buddy pump them 3-4 times when the valve was closed, then when I opened it he pushed on the pedal with all his might and more bubbles came out.
Where is the noise coming from when you're letting up? Like a sealing off sorta suction noise?
post #8 of 20 Old 04-10-2010, 04:03 PM Thread Starter
Tcarsten
Yea sounds like a seal is bad
sounds like the fluid is moving around
I have my dad helping he is pumping while i open the bleeder
Ive never had this kind of trouble
Tcarsten is offline
post #9 of 20 Old 04-10-2010, 04:08 PM
provinT13
I would check the master. If you think it's done for, then take a look and maybe a pic. I wish I could drive down to help ya guys out, just a little too far
post #10 of 20 Old 04-10-2010, 04:13 PM Thread Starter
Tcarsten
NO dont even worry Its fine
Thank you though
I think im gonna get a new one
Tcarsten is offline
post #11 of 20 Old 04-10-2010, 04:24 PM
Straycur
You should be doing it like this:
Bleeding Car Brakes - How To
Make sure whoever is helping you is pushing on the pedal when you open the bleeder, not pumping.
Straycur is offline
post #12 of 20 Old 04-10-2010, 04:25 PM
provinT13
^ Exactly. Make sure he's pumping them, then slamming that sucker to the floor, then you open the valve
post #13 of 20 Old 04-10-2010, 04:37 PM Thread Starter
Tcarsten
yea thats how i have been doin it
Tcarsten is offline
post #14 of 20 Old 04-12-2010, 05:45 PM Thread Starter
Tcarsten
K so the problem is still there
Ive been bleeding them for 3 days now nothing but fluid the pedel is hard till I let off, so if i was driving it i would have to pump them to keep presure.
I replaced the master today well actually my dad did since my broken hand wont let me, no chages.
can the proportioning valve be bad???????
Im really lost any help would be awesome
Tcarsten is offline
post #15 of 20 Old 04-12-2010, 05:58 PM
dodger889
Is it hard when the engine is off ? and when it running is soft? Then you might want to look at the brake booster. or you have the wrong stroke in the peddle.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
what are you doin to your tj w/ your tax return? Alex74012 Wrangler General Discussion 35 01-16-2010 07:26 AM
doin a 2.5 re lift but want new shackles saharajeepman YJ Wrangler Technical Forum 0 03-25-2007 11:24 PM
Doin your own gears?? GKTJ TJ Wrangler Technical Forum 12 11-21-2005 02:18 AM
was i doin somethin wrong hockeynhoots10 YJ Wrangler Technical Forum 23 09-08-2004 09:23 PM
