Am i covering all issues for my soa with these items?
| Ruffstuff Axle Simple Swap Kit! | RUBICON EXPRESS Lift Kits and Accessories Available at Bas | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line |
#1 | |
ok here is what im doing:
1)I have a xj front driveshaft for my cv drive shaft 2)sye 3)rocky road complete kit with steering, shocks, and shakles 4)BFG km2s with crager soft 8s 5)ford 8.8 6)more 8.8 kit 7)4.56 gears front and rear 8)chromoly shafts for the d30 is there anything im missing? ive researched and researched and i think i have it all covered
#2 |
hmmmm... this would be a great sticky if you got all the info and part numbers!
My JEEP is just a project until it becomes an obsession... http://i666.photobucket.com/albums/v.../yjsticker.jpg |
#3 | |
brakes/brakeline replacing or re-routing?
swaybar disco's/removal tracbar?
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield RED JEEP CLUB MEMBER 536 Originally posted by Crazyquadder: Quote:
#4 |
I believe there is already a parts list in the FAQ section.
#5 | ||
Max ![]()
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#6 | |
Jello Puddin'
I believe you're right.
#7 |
the kit that has the breaklines and everything. its got everything for a bolt on but im gonna weld it down
#8 |
i searched but i couldnt find the faq. if you guys know where its at could ya let me know?
#9 | ||
Max
#10 |
ohhhhh ok i gotcha. i think im gonna fabricate some for the 8.8
#11 |
unless ya know where i could get some cheap ones
#12 |
Free clues & suggestions
In the FAQ thread - it's in the Suspension area.
Here's a link to it. http://www.jeepforum.com/forum/f12/soa-parts-list-reference-guide-471769/ |
#13 |
what size tires do you plan to run and what transmission do you have?
the reason i ask is that if you are going bigger than a 33 I would go to 4:88 r&p i got my 8.8 swap kit from ruffstuff specialties, very beefy parts , well worth the 100 bucks IMO also add to your list a good angle finder or a laser so you can get the pinion angle right on the rear axle. a drop pitman arm brake line extension for the rear does your 8.8 have disc brakes? if so you wanna have two short lines (the rubber ford ones) good luck |
#14 |
yeah it has discs. what short lines? breaks? the kit comes with break lines. what is a drop pitman arm? and ill look for an angle finder. thanks guys
#15 | |
He says he's getting the RRO high steer. He won't need a drop pitman arm in that case.
![]() Max ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
