aluminum wheel restoration - JeepForum.com
post #1 of 12 Old 12-24-2013, 12:59 AM Thread Starter
Spiderxx
In the process of removing the old beat up clear coat from my yj aluminum wheels. I got one down to the aluminum so far but I am running into some spots that arent coming off. It is just stuck on the aluminum.
Whats everyone using to get those tough spots off their wheels?
Ill post pics later on of what Im talking about for a better visual.
Spiderxx is offline
post #2 of 12 Old 12-24-2013, 01:35 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I polished a set of horribly pitted wheels and a aluminum valve cover once. The advise I can give is start wet sanding with 500 grit paper then jump to 800 grit, then 1200, 1500,2000,3000. they will turn out nice but it is time consuming and a complete pain in the butt
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 12 Old 12-24-2013, 08:57 AM
Reno72
I used paint stripper, wire brush and water. It all came right off. I have not re-coated them but use navel jelly and a soft brush to clean brake dust off the fronts.
Reno72 is offline
post #4 of 12 Old 12-24-2013, 12:08 PM
Jeepsr4me
paint stripper.. Works great.
Jeepsr4me is offline
post #5 of 12 Old 12-24-2013, 04:00 PM
Reno72
Yep, takes no effort, the coating just gels up and washes off. Here is one of my 21 year old rims.
Reno72 is offline
post #6 of 12 Old 12-24-2013, 05:06 PM Thread Starter
Spiderxx
Thanks guys. Ill post up some photos of mine asap. I am using some paint stripper which is very helpful but some dark spots arent coming off. I tried a bit of sand paper which did seem to help but I didnt want to lose the machined ribs on the wheels. The spot is down in between the ribs so it seems. When I get the pics up it'll explain more of what Im talking about.
Spiderxx is offline
post #7 of 12 Old 12-24-2013, 08:30 PM Thread Starter
Spiderxx
Spiderxx is offline
post #8 of 12 Old 12-25-2013, 06:43 AM
Jeepsr4me
If you got a blaster near by they can strip all that off for about 30 a rim.
post #9 of 12 Old 12-25-2013, 12:32 PM
GaryEMS
The clearcoat on there can easily be removed with some aircraft stripper. I did that to a set of wheels on my K5. Stripped em.. sanded the machine grooves smooth and polished them with Mothers and a powercone. If I would have had the right buffing pad, I have a brick of jewelers rouge but .. alas.. no buffing wheel for my drill.
GaryEMS is offline
post #10 of 12 Old 12-25-2013, 01:23 PM
jsawduste
2006 YJ Wrangler
The brown staining will come off with a application of Bar Keepers Friend. You can find it at most any store in the cleaning section. Like Comet Cleanser stuff
It is a mild abrasive with a bit of solvent like tendencies. Sprinkle it of and scrub with a sponge.
jsawduste is offline
post #11 of 12 Old 12-26-2013, 08:46 PM Thread Starter
Spiderxx
Thanks fellas, I guess the stuff in the machined grooves will have to be sanded out then?
Spiderxx is offline
post #12 of 12 Old 12-27-2013, 09:08 AM
zeus87gn
1987 YJ Wrangler
000 steel wool, dish soap (or bartenders friend) and HOT water for the insides of the rims
The outside will get scratched doing this so the fine sandpaper should work
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
