Alternator Wiring - JeepForum.com
post #1 of 4 Old 08-20-2009, 02:57 PM Thread Starter
demesauce
Alternator Wiring
Hi there, been trying to re-wire my jeep for a while now. Almost all done but I am stuck on the alternator. My jeep is an 1988 YJ with the 4.2, but I recently did the MPI conversion. Everything went pretty well, just time consuming. The jeep starts and runs, but the old alternator is still in place. It seems to be charging, but keeps kicking the check engine light on. I bought the 92-95 style alternator, but need some assistance on how to wire the thing. Any help would be appreciated. I read somewhere about the Dealership part # 56017763, but I'd rather now spend the $135. Thanks a lot
Phil
demesauce is offline
post #2 of 4 Old 08-20-2009, 06:42 PM
Alfons
Phil
First you might want to check on what the stored diagnostic codes are that cause you to get a check-engine-light.
I'm assuming that you have installed the 4.0 engine bay harness if you went through an "mpi conversion", and if so, all the wiring/connectors are there to correctly attach a "new style" alternator - this alternator needs the ECU to regulate the charging voltage.
What's the dealership part you mention in your post?
Alfons is offline
post #3 of 4 Old 08-20-2009, 07:51 PM Thread Starter
demesauce
All of the error codes refer to the alternator. I have the ECM/wiring harness from the 4.0 jeep. And the error code is saying that the alternator is not talking to the ECM. The problem is the wiring harness is from the 4.0 but the alternator is from the 4.2. I need help wiring up my new 4.0 alternator to the rest of my 4.0 system.
post #4 of 4 Old 08-20-2009, 08:16 PM
Gobi_Gred
1987 YJ Wrangler
I just went through this yesterday. If you have a 4.2 alt. then you should need to install a 7.5 amp diode on the feild wire from your new harness. If you have a 4.0 alt. then there should be 2 green wires on the back of it. One should have a black stripe. Im a little foggy on which one is which but one of them hooks to the alt. feild wire from your new harness the other gets hooked to a switched 12v source. The feild wire in my Hesco harness is blue.
Gobi_Gred is offline
Alternator wiring upgrade rami YJ Wrangler Technical Forum 2 12-29-2009 09:45 PM
Alternator wiring question tx_medic YJ Wrangler Technical Forum 12 08-11-2009 07:49 AM
Alternator Wiring SI-10 Gr8archer TJ Wrangler Technical Forum 0 05-29-2009 06:59 AM
4.0 swap - wiring alternator brianOU YJ Wrangler Technical Forum 3 04-23-2009 07:12 PM
Alternator wiring Squealer YJ Wrangler Technical Forum 13 03-10-2009 08:35 AM
