alternator welder write up - Page 7 - JeepForum.com
post #91 of 141 Old 12-15-2011, 08:52 PM
oldtime_ironman
Originally Posted by Ripper3494 View Post
another way to tension it would be those two threaded rods with a hook on either end... one rod is reverse threaded so when you spin the middle sleeve it spreads and pulls em together (cant think of what its called right now) but that may work as well
Its called a turnbuckle. Got em at the hardware and at marine supplies. Cheap and effective FTW!
oldtime_ironman is offline
post #92 of 141 Old 12-15-2011, 08:56 PM Thread Starter
Ripper3494
Originally Posted by oldtime_ironman View Post
Hey Ripper, what do you think of this idea? Maybe you could use an electric A/C clutch on the alt for the belt? That way you could use the same switch for the belt drive *and* the field wire. Or weld on an old vise-grips to a bracket to tension it?
thats actually a really good idea... thatll allow you to not run the alternator when your not using it (apparently thats bad for it). if i remember correctly the clutch assy sticks out further than an alternator pulley, so id have to re make my mounts and move my alt back, but for you guys thatd be a really good way to go i think, then you dont have to screw around with any of the set up before you wanna weld.
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #93 of 141 Old 12-15-2011, 08:58 PM Thread Starter
Ripper3494
i stand corrected, that would actually line up well, id just need to find a car with a v belt system
build thread:
RC vs BDS
post #94 of 141 Old 12-15-2011, 08:59 PM Thread Starter
Ripper3494
the only problem i see with that design is youd either need a very high output alternator, or very high rpms given that the ac compressor clutch is a much larger diameter pulley than the average alternator
build thread:
RC vs BDS
post #95 of 141 Old 12-15-2011, 09:29 PM
ruthole
The only thing im not sure bout is the lead wires as the other on top. I'll worry bout that when I get there though.
94 yj, 4" RC lift 1" shackles, 33's interco M/T's, SRC front bumper, custom built rear bumper, cb, Hi-lift, D30 OX locker, 8.8 LSD,
Lone jeep club member #1
Originally Posted by TMSquy View Post
If parts aint flyin you aint tryin!
ruthole is offline
post #96 of 141 Old 12-15-2011, 09:31 PM
ruthole
But if this is mainly for quick fixes in the field what's the point (besides its cool as hell) of having it if you run the risk of ****ing you keep up wile welding on it (I'm still doing it though)
ruthole is offline
post #97 of 141 Old 12-15-2011, 09:52 PM Thread Starter
Ripper3494
you can weld up other peoples rigs, and if you get good at it you can just use it as an all around welder. as long as your careful your risk of ****ing your electronics up is minimal.
build thread:
RC vs BDS
post #98 of 141 Old 12-15-2011, 09:53 PM Thread Starter
Ripper3494
lemme know when you get there and ill walk you through the wires
build thread:
RC vs BDS
post #99 of 141 Old 12-15-2011, 10:26 PM
bikerdude
1987 YJ Wrangler
Turnbuckle. That would be an easy way to tighten it. I need to do this mod, looks like it works great.
bikerdude is offline
post #100 of 141 Old 12-15-2011, 10:27 PM
meSiLlY
You too? Stick, mig, tig and gas here. Mostly ASME boiler section 8 and 9 (repair).
No the field wire won't screw with anything else, but I would put a fuse in it tho.
Awesome!! The AC idea is brilliant. Like ripper stated though.. the diameter of that belt is to big but.. It still might be doable if we can weld or fab a smaller pully on the front of the clutch assembly. The center portion doesn't spin unless the clutch is engaged. I'm gonna take a look at that.
I like the vise grip idea too. We've used vice grips in unorthodox ways before. lol.. As a lineman.. we welded clamps to them and they became snubs. It holds lashing to the strand.
Was worried about that field wire, Thanks!
i thought about putting it on a serpentine belt but the v belt set up was just simpler for me and it fit really well. this way i just slip it on and off. to be honest the reason i picked the v belt was because i thought it didnt really need to be tight like a serpentine... our tractors isnt tight and it works, but oh well its good now.
the field wire wont mess with anything other than drain your batt, its just a direct connection from batt to field terminal on the alt
Cool.. Yeah.. nothing wrong with the V groove. It's worked that way for years.
Good deal about the field wire. I don't want to chance anything messing with the ride home.
oldtime_ironman beat you to it but that's all good. Had he not.. you'de be bringing it. Happy to hear input period. The internet is great! AC clutch is an awesome idea and aside from the pulley size issue (mentioned by ripper).. I think it's doable!
Can't wait to get started!
meSiLlY is offline
post #101 of 141 Old 12-15-2011, 10:36 PM Thread Starter
Ripper3494
another thought, how hard does the ac clutch hold, because the alt becomes very difficult to turn when you draw from it, not sure if the ac clutch will stay engaged with that. once again i have no idea just throwing the thought out there
build thread:
RC vs BDS
post #102 of 141 Old 12-16-2011, 12:01 AM
ruthole
I'm good at stick (all they taught when I was in school) but I'm going to talk my buddy into doing one on his boat where he can weld mine without a risk of messing my own up. I like my kenwood and my ECU
ruthole is offline
post #103 of 141 Old 12-16-2011, 12:03 AM
ruthole
Ok cool. JF messaging it will take a wile though (I'm nowhere near the best wire runner in the world)
ruthole is offline
post #104 of 141 Old 12-16-2011, 12:20 AM
oldtime_ironman
I've heard the typical AC unit can hold about 3 hp. Dunno how to back that up tho. I would actually adapt the clutch to the crank instead of putting it on the alt so you don't have to worry bout enough RPM's. Basically all you would need is a custom made bolt or stud - easy job to do. Kind of "double-ended" like a great big stud on one end, nut in the middle, and a 1/2 inch smooth shaft on the other end.
Imagine if the crank pulley bolt had a shaft sticking out from the middle of the bolt head, so you could stack the AC clutch on top of the crank pulley.
post #105 of 141 Old 12-16-2011, 02:35 AM
meSiLlY
I like it! PTO! heh...
meSiLlY is offline
Any write-ups on how to change alternator on 4.0? MountainMan864 TJ Wrangler Technical Forum 16 09-19-2011 09:57 PM
Would this Welder be Enough spawnofsatan YJ Wrangler Technical Forum 17 07-06-2011 11:36 AM
arc welder mylightsrsquare YJ Wrangler Technical Forum 26 11-09-2010 08:25 AM
Just got a welder! ufatbastehd YJ Wrangler Technical Forum 7 05-05-2008 07:44 AM
What welder to get? MasterD TJ Wrangler Technical Forum 4 05-03-2006 09:51 PM
