alternator welder write up - JeepForum.com
post #1 of 141 Old 12-14-2011, 08:49 PM Thread Starter
Ripper3494
so hopefully im putting this in the correct area... but here it goes, i was asked to do a write up of my alternator powered welder on my jeep.
i apologize ahead of time if its difficult to follow this is my first write up
things you'll need
1. alternator (must be externally regulated, such as the ford alternators.) i used one out of a 1981 cougar with the 5.8l v8. its best if the output of the alternator is 70+ amps mines 110 amps
2. some thick gauge wire (2 or 4) will work
3. some thinner wire. just to excite the alternator (must be detachable, you dont want to leave plugged in while not in use)
4. a way to mount the alternator in your engine bay (home made brackets work)
5. extra pulley (or if you can bolt it on your belt where it fits thats great too)
6. belt (once again not needed if it fits somewhere on your stock belt)
7. a stinger to hold the welding rod (or you could use jumper cables, stinger is best)
8. a way to adjust engine rpms without pedal.
i know it sounds like a lot but really its not as much as it sounds. i dont have pictures of me installing it but i have them of it finished so ill try to walk you through it
this picture shows the mount that holds the alternator on the frame, it was made from metal that i had laying around. i cut 2 right angles out of it, welded them onto the frame 3 inches apart, drilled holes in em and mounted the alternator on top.
since my system is used only when needed i made things easy to disconnect. alternators become more difficult to turn when you draw power from them, and since welding takes quite a bit of power you'll need a way to tighten the belt so the alternator doesnt slip, i used a ratchet strap hooked on to my frame on one side and the other end on a bolt going through the alternator.
you'll have to excuse my wiring (the v8 swap isnt fully completed) but the red wire up on top here goes directly from the battery's positive to the field terminal on the alternator
the red and black wires coming of the alternator will be your direct ground and positive. obviously black is ground and red will go to your stinger.
this is a bad picture but you can see where that red and black wire lead. the front of the grill where i clip my leads onto.
and there you have it. your alternator welder is complete. time to try it out.
the way i have things work is i use a set of jumper cables clipped onto those wires coming off the alternator, then i clip the positive of the jumper cable to my stinger and the negative continues to be the ground.
heres a quick video of it working. please i dont need a lecture on proper welding equipment, i made the video spur of the moment and didnt have my gloves/mask with me. and yes my eyes were closed i just wanted to show that it works.
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #2 of 141 Old 12-14-2011, 09:13 PM
squazz
Good deal
squazz is offline
post #3 of 141 Old 12-14-2011, 09:18 PM
jeep0312
Awesome. Now to fit that on the ZJ....
-Travis-
2004 Chevy Malibu, red, 2.2 ecotec, shiny wheels, loud stereo
2000 Suzuki SV650N, V-twin, Yoshimura Exhaust, Custom Rashed Paint Job...
jeep0312 is offline
post #4 of 141 Old 12-14-2011, 09:18 PM
Mark455SD
1961 CJ5
That engine sounds sweet.
Mark455SD is offline
post #5 of 141 Old 12-14-2011, 09:27 PM
oldtime_ironman
I like it... something I've wanted to do for a *long* time!
Just in case you'd like to know... big diesel truck alts are the best for this, I mean mack and freightliner, thermo-king refrigerator trucks, etc. Reason being most of them are 24-volt instead of 12 volt. Also, it takes about 120 amps to burn 1/8 inch rod. Regular welding machines (good ones) will keep about 28 volts at whatever amps you put.
Obviously the ford alt worked, and its lo-buck cheap-n-easy mod! I love it!
oldtime_ironman is offline
post #6 of 141 Old 12-14-2011, 09:28 PM Thread Starter
Ripper3494
there is a way to do it using the stock alternator. still has to be externally regulated though. but you get a 110v regulator from autozone with a switch and you can switch it from powering your jeep to being a welder.
build thread:
RC vs BDS
post #7 of 141 Old 12-14-2011, 09:31 PM Thread Starter
Ripper3494
thanks for the tip, ill look into that once this alternator burns out (made in china) the way i have it mounted i can easily switch whatever i want into it. at idle the alternator is outputting 34 volts though so its doing fairly well, i did a test a few days ago at 5000rpms just to see and it was right around 213 volts. so at about 3000rpms i can actually run grinders and tools like that off of it. as long as the motor has brushes
build thread:
RC vs BDS
post #8 of 141 Old 12-14-2011, 09:32 PM Thread Starter
Ripper3494
thanks, its just a flowmaster 44 clamped onto flexible pipe until i get my c6 headers in the mail
build thread:
RC vs BDS
post #9 of 141 Old 12-14-2011, 09:33 PM Thread Starter
Ripper3494
a question though, with a 24 volt alternator would that mean id have to supply the field terminal with 24 volts instead of 12? im planning on running dual batteries so i could figure out a way to give it 24 if i had to, just wondering
build thread:
RC vs BDS
post #10 of 141 Old 12-14-2011, 09:44 PM
oldtime_ironman
Nah you could just field it with 12v. In fact it'll prolly last longer that way.
Here's another idea:
http://www.dbelectrical.com/p-3907-n...p-amo0045.aspx
Most alts you can rip out the internal reg or just bypass it by snipping a few wires, make it do whatever you want. Kinda like doing a nutter bypass on the alt itself.
(FWIW I used to be a pro welder/fabricator... at work the welder ran off a diesel, the alt on it weighed 700 lbs, 400 amps...) Scroll down for pic on this page...http://weldingweb.com/showthread.php?t=4694
post #11 of 141 Old 12-14-2011, 09:56 PM Thread Starter
Ripper3494
Nah you could just field a 24 v alt with just 12v. In fact it'll prolly last longer that way.
that alternator is tempting... i knew about being able to modify other alternators, i just didnt wanna chance screwing one up so i figured the safest route for me was an external regulated one. and that sounds like an epic welder. im fully open to any ideas you or anyone else may have for improvements (just throwing that out there). i may look for a used 24 volt alternator like the one you posted. that would allow me to weld without revving the engine up near as much
build thread:
RC vs BDS
post #12 of 141 Old 12-14-2011, 10:09 PM
oldtime_ironman
If you want to use both pullys on your alt, try finding an older chevy or GMC straight 6 cylinder at a junkyard. From the 1960's or 1970's. Double pulleys were standard on them. You could stack one of them on top of your regular crank pulley. That way you won't have to winch on your alt so hard to keep it from slipping.
The machine I used at work was just a regular construction site welder, big blue box with a muffler on a trailer.
http://www.google.com/products/catal...ed=0CGIQ8wIwAQ
^^^ like that one... gonna have to save up a bit for that tho...
post #13 of 141 Old 12-14-2011, 10:14 PM Thread Starter
Ripper3494
only problem is the pulleys are different sizes on the alternator, inner one is deeper so id need to have a way to offset the difference in pulley size. the first time i tried it i figured i had enough tension just having it bolted in and it killed the belt in like 5 seconds. i didnt know much about alternators so i didnt think it could be that hard to turn... so very wrong
build thread:
RC vs BDS
post #14 of 141 Old 12-14-2011, 10:16 PM Thread Starter
Ripper3494
i think ill be good with the hobart in the garage for awhile before ill require a $13,000 welder lol. i can imagine it'd be pretty fun using it though
build thread:
RC vs BDS
post #15 of 141 Old 12-14-2011, 10:17 PM
oldtime_ironman
that's weird, never heard of diff size pulleys before... OTOH I think the shaft on car alts is a standard sizes for all of them, if I remember... maybe there's a different one you could swap on?
Any write-ups on how to change alternator on 4.0? MountainMan864 TJ Wrangler Technical Forum 16 09-19-2011 08:57 PM
Would this Welder be Enough spawnofsatan YJ Wrangler Technical Forum 17 07-06-2011 10:36 AM
arc welder mylightsrsquare YJ Wrangler Technical Forum 26 11-09-2010 07:25 AM
Just got a welder! ufatbastehd YJ Wrangler Technical Forum 7 05-05-2008 06:44 AM
What welder to get? MasterD TJ Wrangler Technical Forum 4 05-03-2006 08:51 PM
