Alternator upgrade success! - Page 2 - JeepForum.com
post #16 of 24 Old 10-07-2012, 09:12 PM
dillonjm
2013 WK
Originally Posted by mudsling View Post
Dillonjm, those tube fenders look great. I spoke to Chris (c & c fab), he took the time to answer my questions, real pleasant guy. I also order a rear bumper from Dirtyworx, I will be building the tire carrier myself. I will post pics when I am done.
He seemed like a nice guy when I was down there as well. I think you'll like them.
Looking forward to the pics.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #17 of 24 Old 10-07-2012, 09:46 PM Thread Starter
mudsling
Dillonjm, I also fabricated a gas tank skit, holders for the quick disconnects on the sway bars and even painted the jeep in my back yard. I will get all the pics posted once I am done. Trying to finish before it gets too cold here in NY.
mudsling is offline
post #18 of 24 Old 12-31-2012, 03:56 PM
shockboss17
I want to thank you guys in the know for all of the good information provided in this forum. I have a 94YJ 2.5L. I have KC lights, winch, stereo, etc. I research for the best way to up grade the original alternator in my jeep, this is what I came up with, with you guys help of course.
First I bought a Diehard P2 $240, which fits perfectly on the YJ battery Tray. I bough a 25' roll of welding wire #2 ($50), cable lugs. I re-wire all of my negative and positive cables, example: battery (-) to motor and battery (-) to fire wall. Battery (+) to starter, battery (+) to PDC.
Alt I bought at Autozone for a Jeep Grand Cherokee 136amp $130. Direct fit. Disconnected the 6 gage ground wire going to the engine and replace it with #2 welding wire. The positive side I ran to a 150 amp ANL fuse and fuse holder then to battery positive.
On a side note, you may wonder about the cut out fenders, I am waiting for a set of tube fenders from C & C Fabrication.
Did a test run. Hooked up to my dump truck from the bottom of my drive way, all lights on, stereo on, on idle I winched myself to the top (I would not do this on a real winching situation). No sweat.
Thanks guys
All you had to do was swap the alternator then upgrade the wire that has a higher fuse able link? I'm trying to do this in my 2.5l yj
shockboss17 is offline
post #19 of 24 Old 12-31-2012, 06:54 PM
G30SFF250
OP,
I would to read this thread.
Is there anyway you could resize the pics so I can see the printed words?
Thank you!
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline
post #20 of 24 Old 01-01-2013, 03:57 PM
shockboss17
Thanks guys
I'm doing the same thing, besides the alt being direct fit. All you did was upgrade the wires running off the alt, and you used #2 welding wire n used that to replace the ground side? Was it pretty simple??
Thanks
post #21 of 24 Old 01-01-2013, 04:32 PM
NHfireLJ
NHfireLJ's Avatar
Thanks
Typically with hi amp alternators you upgrade the Big 3.
•Upgrade the charge lead from the alternator output stud to the battery, with a 150 Amp fuse
•Upgrade the return path between the alternator and vehicle ground
•Upgrade the return path between the battery negative (-) and the vehicle ground
4AWG is more than adequate fr a 136 Amp alt
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #22 of 24 Old 01-01-2013, 05:01 PM
shockboss17
Okay and the 150 amp fuse, can you get in in the 4AWG or does that have to run through the box?
post #23 of 24 Old 01-01-2013, 06:53 PM
NHfireLJ
NHfireLJ's Avatar
Something like this... http://ceautoelectricsupply.com/alte...ationkits.html
or make your own..
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #24 of 24 Old 01-01-2013, 07:18 PM
shockboss17
or make your own..
Thanks a lot I'm gonna get this kit. I'm also gonna get the GC alternator from auto zone I believe it's 136amps. Ill take pics and let ya know how it turns out !
