Alternator upgrade questions. - JeepForum.com
post #1 of 8 Old 05-20-2010, 09:53 PM Thread Starter
rocknjeep
1987 YJ Wrangler
So my alternator is pretty much ready to die. I want to upgrade to the 136amp one out of a 98 Grand Cherokee. I currently have the original alternator from 87. What do I need to do to make it work? Or can I? I know it's a bolt in situation and that it will fit. But I'm assuming I'd need to mess with some wiring to make it work. Have any of you guys done this before?
rocknjeep is offline
post #2 of 8 Old 05-20-2010, 10:05 PM Thread Starter
rocknjeep
1987 YJ Wrangler
and i do believe from more reading it's the delco. why the PO who put in a 4.0L out of a cherokee didn't keep it MPI or use the alternator that had I'll never know.
post #3 of 8 Old 05-20-2010, 10:08 PM Thread Starter
rocknjeep
1987 YJ Wrangler
and now with further research I think I may have solved the problem I was looking at.
Store Locator | NAPA Online
post #4 of 8 Old 05-20-2010, 10:12 PM Thread Starter
rocknjeep
1987 YJ Wrangler
now my question is am I going to blow up the jeep by going from 78amps to 136amps?
post #5 of 8 Old 05-20-2010, 10:26 PM
dodger889
Just use a heavier led wire for the battery to the alt. +
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #6 of 8 Old 05-20-2010, 10:39 PM
5-90
5-90's Avatar
1988 XJ Cherokee
I seem to explain this about once a week, somewhere.
Check your alternator - if it's OEM, the 136A ZJ/WJ upgrade will not just bolt in and work!
Prior to 1991, Jeeps were still built to AMC specs. That means Delco internally-regulated alternators (the XJ and MJ got the CS-130, and the YJ got the 12SI.)
The Nippondenso, used by Chrysler 1991-up, is externally regulated by a circuit in the PCM. Therefore, you will not have a voltage regulator, and one of two things will happen (depending on how you end up wiring the thing up):
1) You don't connect anything at all to the two studs on the back, and you get no output (due to no input to the field coils.)
2) You do some cutting and crimping, and feed the regulator sense circuit to the field coils. The field coils typically get 0.5-4.0VDC (more voltage to the field coils means more current out of the alternator,) but the regulator sense circuit means full system voltage. This means that:
A) The alternator will swing well beyond max output - we're talking 90-100VAC @ 300-400A.
B) The diodes will either blow out ("open") or short through ("closed" or "short".) If they "fail open," you won't get anything out of the alternator. If they "fail short" or "fail closed," you'll get that 90-100VAC @ 300-400A, and that will blow out pretty much all of your solid-state electronics!
There's an alternator ID guide on my site for later models (Kelley's Works in Progress & San Jose Generator, at the moment. I'll be reorganising the site sometime soon...) to help you figure out which you have. The first pair of pix is front/back on the 12SI, the second pair is F/B on the CS-130, and the third set is F/B on the ND.
This doesn't mean you're boned - the Delco SI and CS series alternators are actually the most popular alternators for conversion installs, kit builds, secondary installs, marine installs, industrial equipment, and quite a few other things (I once overhauled a Hobart GPU - Ground Power Unit - that used a Ford 140ci long block, Ford 122ci bolt-ons, and a Delco 12SI wound to 40A to keep the engine running. Most bizarre damned thing I'd worked on in years...)
Any competent shop can upwind a Delco for you in short order, and getting a Delco wound for 140-150A is a piece of caek.
NB: If you uprate your alternator, you will need to upgrade your cabling and fuse protection! I can help you with that, if you need it.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #7 of 8 Old 05-20-2010, 11:40 PM
jbolty
jbolty's Avatar
what he said ^^^^.
you want a CS-144, unless you are now running a 4.0 and related electronics
jbolty is offline
post #8 of 8 Old 05-21-2010, 06:49 AM
Que89YJ
If the PO did not install the computer when he converted over to the 4.0L then you need to use the CS-144. The Voltage Regulator for the post 1990 are in the ECU. No ECU means no regulator. The 1990 and prior are internally regulated. The CS 144 is the right one for you
Que89YJ is offline
Alternator Upgrade Installation Questions cyberiv TJ Wrangler Technical Forum 5 03-29-2010 08:06 PM
my alternator went out, what to get as an upgrade? evoGibson YJ Wrangler Technical Forum 3 02-16-2010 07:44 PM
Alternator upgrade bilabong TJ Wrangler Technical Forum 3 11-09-2008 02:43 PM
Alternator Upgrade? 08 Sahara YJ Wrangler Technical Forum 12 11-13-2007 10:56 PM
Alternator upgrade 2000yellowtj TJ Wrangler Technical Forum 1 05-18-2006 05:53 PM
