Alternator upgrade - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Alternator upgrade
The Solution to Radius Arm Bind - Meet Lock-N-LoadFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 09-03-2014, 09:15 AM   #1
CB10101
Alternator upgrade
I've been researching the cs144 alternator swap and pricing all the parts new/reman. While looking through a summit racing catalog I found p/n sum-810344. This is a 140A 10si with a v belt pulley installed for $120.
Wouldn't this be a more direct change over instead of requiring a cs to si cable and bracket modification? I don't have the dimensions yet, but guessing 10si is a fairly standard design and might not require bracket mods at all.
CB10101 is offline   Reply With Quote Quick reply to this message
Unread 09-03-2014, 09:36 AM   #2
jbolty
jbolty's Avatar
The CS144 is a pretty large case but it's not a lot of work to make it fit. The SI type alternators are a little smaller generally and are also self regulating. Either would work and are all available for cheap at any junk yard.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote Quick reply to this message
Unread 09-03-2014, 10:54 AM   #3
Que89YJ
Car-parts.com. The SI will work
http://www.jeepforum.com/forum/f12/c...4-2-a-1567597/
Use car-parts.com
You can get a used one for around $50
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 09-04-2014, 02:20 PM   #4
pushead
I bought a 160 amp alt from this guy years ago. http://www.motorcityreman.com/high-a...-wrangler.html Not sure why he only list 91-98 because mine is an 88.
Its not a jeep if it dont have 4wd.
pushead is offline   Reply With Quote Quick reply to this message
Unread 09-04-2014, 02:42 PM   #5
jbolty
jbolty's Avatar
The alternator in that link will not work on a 4.2 engine setup, at least not easily.
Unread 09-04-2014, 02:44 PM   #6
pushead
Well that is where I bought mine and I have a 4.2. Direct bolt in as well. But that may be why it say 91-98 on the add. I would still give him a call.
