Alternator swap questions - JeepForum.com
post #1 of 10 Old 06-05-2013, 06:59 PM Thread Starter
shnitzle
I have an 88 yj and just swapped in a 92 engine
Im having some trouble with the alternator wiring,
should I use the denso alternator from the newer engine?
if so how do I wire it in.
or should I use the older delco?
If so how do I change the pulley
I have brackets and wire harnesses from both engines.
shnitzle is offline
post #2 of 10 Old 06-05-2013, 07:12 PM Thread Starter
shnitzle
2.5l
shnitzle is offline
post #3 of 10 Old 06-06-2013, 07:09 AM
Que89YJ
Que89YJ is offline
post #4 of 10 Old 06-06-2013, 07:26 AM
jbolty
jbolty's Avatar
The delco/cs-144 can be made to work, but it's not easy. Your voltage regulator is in the ECM so without the proper alternator you will most likely get a check engine light. I have read threads about hacking the wiring with a light and/or a resistor in the circuit but it seems like an extra headache
jbolty is offline
post #5 of 10 Old 06-06-2013, 08:29 AM
Que89YJ
Oh sh## I didnt see he swapped in a 92!
If you just swapped the engine then it is still like I said. You use the CS 144. The TBI engines and all the 4.2L were all internally regulated and you need the CS 144. Jbolty is right, if you have the 92 harness and computer then you need to use the Grand Cherokee mod!
Que89YJ is offline
post #6 of 10 Old 06-06-2013, 08:58 AM
Siva283
98 grand cherokee is the alt. Also a 98 durango with snow plow package. Make sure you get the optional one because standard was the same 90 amp we already have. Should be about $130 new at Advance Auto
I have also discovered that a 2001 GC limited has the 136 amp alt we use as well.
Ask me how I know...
Siva283 is offline
post #7 of 10 Old 06-06-2013, 11:19 AM
PA_YJ19
The 5.2l zj grand Cherokees also come with the 136 amp alternator usually. They r the older square type grand cherokee. Just count the number of rings on the alternator pulley, if it has 7 then that's the one u want. The 100 amp and the 75amp alternators have 6 grooves on the pulley.
PA_YJ19 is offline
post #8 of 10 Old 06-06-2013, 08:18 PM Thread Starter
shnitzle
sorry I did not make myself clear,
i kept the TBI, and have it set up with the serpentine belt system.
Im thinking the easiest thing to do would be to put the serpentine pulley (from the denso) onto the older delco alternator. that way the wiring wont be a problem.
would the denso pulley fit on the delco alternator?
would everything line up?
shnitzle is offline
post #9 of 10 Old 06-06-2013, 08:25 PM
Siva283
Yes you should be abke to swap thw pulleys and that would be the easiest way since you stayed tbi.
Sent from my Galaxy S3 using JeepForum
Siva283 is offline
post #10 of 10 Old 06-06-2013, 08:31 PM Thread Starter
shnitzle
thank you
shnitzle is offline
