Alternator Rebuild? - JeepForum.com
post #1 of 8 Old 01-27-2013, 02:28 PM Thread Starter
bcusstc
Alternator Rebuild?
Has anyone ever had their alternator rebuilt as opposed to just buying a reman or brand new one? I think the bearings are starting to go on mine and i have always just bought a reman but i know there are people out there that just rebuild them.
Looking for everyones .02 with pros and cons. I know i can get a reman for about 100 dollars so i didnt know if it would be worth it or not.
bcusstc is offline
post #2 of 8 Old 01-27-2013, 03:14 PM
Jeepsr4me
I rebuild all mine.. They make kits, and its not hard to clean one up and replace the parts.. Unless the windings have shorted out.
Jeepsr4me is offline
post #3 of 8 Old 01-27-2013, 03:20 PM
JWELK
A 95? It is close to 20 yrs old. Don't you think you got your money's worth. How long do you think it should last? In addition to the bearings the brushes should be replaced, and the slip rings checked. The windings could be meggered to verify they are still at factory spec. While I don't know if the re-manufacturing process covers all of this, 100 bucks is relatively cheap, compared to the usual scenario. Parts don't normally fail on sunny fall days when you have a couple of hours to waste.
You could certainly get your replacement and try re-building your unit, just to keep it stock.
Regards,
Jim W
JWELK is offline
post #4 of 8 Old 01-28-2013, 10:17 AM
Que89YJ
Don't mess with the stock alternator. Upgrade now that you are to the point of replacing it. The GC alternator is a direct bolt in and has a much better capacity.
136 amp alternator*:
1996-1998 Dodge B.Series Van - (PN:56027913 Reman:R6027913)
1996-1998 Dodge Dakota 3.9L, 4.7L, 5.9L - (PN:56027913 Reman:R6027913)
1998-2000 Dodge Dakota - (PN:56027913AB Reman:R6027913AC)
2003-2005 Dodge Dakota 3.9L, 4.7L, 5.9L - (PN:56041693AC Reman:R6041693AC)
1998-1999 Dodge Durango - (PN:56027913 Reman:R6027913)
1996-1998 Dodge Ram Pickup - (PN:56027913 Reman:R6027913)
1998-2000 Dodge Ram Pickup - (PN:56027913AB Reman:R6027913AC)
1991-1998 Jeep Grand Cherokee - (PN:56005685 Reman:R6005685)
2000 Jeep Grand Cherokee 4.7L - (PN:56041324AC Reman:R6041324AC)
2001-2005 Jeep Grand Cherokee 3.9L, 4.7L, 5.9L - (PN:56041693AC Reman:R6041693AC)
150 amp alternator*:
1993-1998 Jeep Grand Cherokee - (PN:56041394AA Reman:R6041394AA)
Que89YJ is offline
post #5 of 8 Old 02-02-2013, 01:59 PM
scottontherocks
Is the 150 amp 1993-1998 Jeep Grand Cherokee - (PN:56041394AA Reman:R6041394AA)[/QUOTE]
A direct bolt in? I have a 93 4 banger.
scottontherocks is offline
post #6 of 8 Old 02-02-2013, 02:44 PM
Que89YJ
Yes.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #7 of 8 Old 02-02-2013, 03:53 PM
kirksjeep
A direct bolt in? I have a 93 4 banger.[/QUOTE]
Yes and no. You will need to swap the main cable connection from your stock yj alternator over to the ZJ alternator since they are180 degrees off. You should also be aware that the ZJ ran a 6 rib belt and thenYJ is a 5 rib. It is easy to swap the pulleys but not required. The last and biggest thing is that you will need to upgrade your. Artery cables. Do a search and you will find lots of opinions on the proper gauge wire.
1992 YJ Sahara- 4.5" RE XD, 1" BL, 1" MML, 35" BFG MT, 8.8 w/Aussie, D30 w/Ten Factory shafts/ Aussie, 4:10 gears, Soild Diff Covers, SYE, CV Drive shaft, OBA, Flowmaster Super 44,, Custom head pipe, Super Chip, Boared out TB, Rock It Intake , Goferit Tie Rod Flip, 99+ intake manifold/Steering pump, custom front/rear bumpers,Hand Throttle, Hurst Shifter, Smitty Built sliders , 6" TJ flairs, Kilby belly up skid, Quadratech 9K winch, ZJ PS cooler. 01 XJ Sport-2" lift, 31x10.50 MT/ 02 Liberty 2" Lift
kirksjeep is offline
post #8 of 8 Old 02-02-2013, 04:57 PM
scottontherocks
Thanks
