#1 | |
Alternator Problems
Well I got my 4 wheel drive working today so I celebrated by playing in the mud. In the process I managed to soak the entire engine bay (with water not mud).
Now my alternator is squeeling and not chargeing as much as it should be. The squeeling is non-existant untill about 900rpms and gets worse as the rpms increase. With no load other than the motor is charges at 14.2. As soon as you turn on lights it goes down to 13.25, and the more you turn on the more it drops. Increaseing RPMs do not improve it's output. I'm pretty sure the belt and pully are dry at this point as well. My question is what specifically in the alternator is most likely to have gone bad? I'd rather replace bearings, a voltage regulator, or whatever has gone bad for a couple dollars than pay $65 for a "rebuilt" one.
#2 |
BUILT. NOT BOUGHT.
sounds like the belt is just wet and slipping, thus creating a squeal.....
wait for it to dry, tighten the belt, and be on your way... should be fine.
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
#3 |
yeah ditto,, the belt probably slipped bad and now maybe its glazed. i would double check the tension too maybe the tensioner or idler is goin south.
#4 | |
1991 Renegade, 4" Rough Country Lift, 32" A/T's on 15x8 Canyons, Fr. Runk Bumper, Rear Warn Rock Crusher Bumper, Ramsey 6000# Winch, 4.10 YJ Axles, Blower Mtr. Upgrade, 150 AMP alternator, ZJ Rear Disc Brakes w/Corvette MC, CB w/Firestik, Half Hardoors, Warn Steering Box Guard, KC Highlights. |
#5 |
Make sure you get all of the mud off the alternator and get it clean and dry. I'm not familiar with what it does to the internal components of the alternator but I do know that mud can make it overhead and eventually crap out. I found this out the hard way by being stuck on the side of the road for 5 hours on the way home from a wheeling trip. Now I carry a spare alternator.
#6 |
i agree with the belt.. mine did that.
4.0 I6 ARB snorkle 307 -> 411 gear swap lock rite locker on the dana 35 33 x 12.50 Mickey Thompson radial MTZ 4.5" Rubicon Express heavy duty Suspension Lift currie boomerang shackles 8,000 lbs. Winch bikini top tonneau cover pictures?? http://www.cardomain.com/id/ironm98 crazymon01@aol.com |
#7 |
Well you guys were right, the next morning it was fine. My belt was plenty tight and it's fairly new so I don't see why it would be been slipping like that. I also checked to see if the belt/pully was wet and it didn't seem to be.
Any ideas on preventing this in the future? |
#8 |
BUILT. NOT BOUGHT.
stop 4 wheeling when it's wet out....
or just put in ear plugs and try to pretend you don't hear it next time since it'll fix itself...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
